WD hydraulic pump
bdd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bdd Quote  Post ReplyReply Direct Link To This Post Topic: WD hydraulic pump
    Posted: 17 Jan 2017 at 7:29pm
Can anyone help me....I just bought a 51 WD I'm strippin it down....How hard is it to pull the hydraulic pump out of it....What all do I got to do
irlbeck A-C'S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote irlbeck A-C'S Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 7:58pm
Not hard at all.
Drain the fluid out of the resovoir underneath tractor next to the pump and the small plug in the bottom of the pump.
Disconnect the lines from hold valve on the top of the pump.Two bolts hold the hold valve on the pump.
Remove the line to the hydraulic cylinder. Usually there is a swivel at the cylinder where you can take the line off. Unpin the linkage.
Take the 5 nuts off and pull pump from in between the tractor and frame rail.
The pump will need to lift up and out a little for the tube on bottom to clear.
B,C,CA,(2)WC's,(4)WD's,(2) WD45'S, 45Diesel, (2)D12'S Series 2, D12 Hiclear,(2)D12 Series 3, HD3, D17NF (3)D17 Series 4 Diesels, M-100 Grader,8550,A few Lawn tractors lots of other AC stuff
