WD Hydraulic Failure?
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Topic: WD Hydraulic Failure?
    Posted: 04 Jun 2010 at 7:11pm
I am a zero when it comes to WD's.  All I have with the books is a D 15 II.  Anyway here is a story.
This guy has a WD with factory hydraulics.  A long time ago he remembers the shifting got messed up and they had to take the cover off the trans and realign the forks and all was well for years.  The other day a friend of his was gonna help him move the tractor by pushing it.  So he reached up and was gonna put it in neutral without the clutch.  I did this many times with different tractors on concrete floors.  Anyway the allegator crawled out of the swamp and the shifting mechanish jumped out of whatever.  So they took the top off realigned everything and put it back together and walla it shifts fine.
Now out of the clear blue he has no hydraulics and thinks something happened when they had the top off the tranny or when his friend put it in neutral.  I don't know if there could be a correlation or not.  Is that possible or what is your wildest guesses as to what we should look for in the am.
thanks in advance.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2010 at 7:20pm
  clutch has to be engaged for hydraulics to work
LarryWC In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2010 at 7:27pm
Norm's right! foot clutch disengages hydraulics on WD's
My WD shifter jumps out all the time so I've got REAL good at fixing it by just pulling the shifter out and setting it wherever I happen to be!
There's probably a "Fix" for that too,but I've not persued it because I'm gonna replace the tranny this fall anyway!
Edited by LarryWC In - 04 Jun 2010 at 7:27pm
www.allischalmersmuseum.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2010 at 7:38pm
OK so surely the guy has let the foot clutch out.  He has had he tractor for eons and used the hydraulics before.  I would not think CRS has set in that bad?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2010 at 7:42pm
There would be no connection between the shifter problem or the fix to it and the hydraulics not working. If the foot clutch is engaged( let out) and the hydraulics don't work, check the fluid level. The dipstick should be at the full mark with the lift arms extended. Any number of other things could cause problems, including sludge build up in the bottom of the reservoir, a broken bypass spool, sticking plungers, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2010 at 10:07pm
does the WD hve the hyd hose and cylinder like on the D series where the hose tends to rupture after a few decades?  This is in the rock shaft rea.  I replaced the hose on the D 15.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2010 at 8:23am
Nope, all of the WD plumbing is external.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2010 at 9:38am
Just got back from looking at the ole WD.  Nice straight all there tractor that purrs like a kitten.  WeLLLLLLLLLLLLLLL, we found this little stubby dip stick on the left side that was dry.  Dumped a bunch of oil in there until it came up on the stick and the hydraulics work like new.  I don't know what to say about that, but thanks again for your time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2010 at 5:24pm
Hmmm,,,yeah,, oil,,,they need oil,,that's for sure!,,ha ha ha
This page was generated in 0.107 seconds.
