Main bearing foot lbs,on a B
Tom Elder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Elder Quote  Post ReplyReply Direct Link To This Post Topic: Main bearing foot lbs,on a B
    Posted: 17 Jan 2017 at 11:50am
I am in the middle of overhauling one of my 2 Bs
I had it line bored ,rods conditioned, sleeves installed   etc. at the machine shop.My auto mechanic of  30 years put  the crank and rods in it yesterday.The machine shop advised him to only torque the main bolts to 50 instead of 80 ,because the were grade 5 not grade 8, .Is this a bad or good move?
 Thanks ahead of time,Tom
2 1949bs,one with belly mower one with side sickle bar
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 12:10pm
why were they changed to grade 5 ?  SPEC is 80 ft pounds on factory bolts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Elder Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 12:17pm
they are what was in it.with holes for safety wire ,i just figured the machine shop could tell by the head markings or something,along those lines,thanks
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 12:22pm
3 head marking means grade 5. The stock head bolts on my WD45 are grade 5's but they are torqued to 90lbs. Seems high for a grade 5 1/2 bolts but that's what the book says. I would do what the manual says. Someone might chime in and confirm that they had grade 5 from the factory. I bet they did.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 3:50pm
I'd follow the shop manual. I ran into a similar situation when I overhauled my 262. Without looking IIRC the head bolt torque is something like 120 ft lbs on 1/2" bolts. Nominal torque on a grade 8 1/2" bolt is like 80 or 90, somewhere in that area. Original A-C bolts are higher. Whatever is in the manual is what the factory did...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 8:45pm
Im not sure all the bolts in 1940 were marked on the heads. Here is a photo that DICK posted a couple days ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Elder Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 9:01pm
thanks bunches  men
