200 Headlight Switch
JMB984 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JMB984 Quote  Post ReplyReply Direct Link To This Post Topic: 200 Headlight Switch
    Posted: 16 Jan 2017 at 7:06pm
First off, I would like to say how much I enjoy this forum!  I have recently acquired a 1972 Allis Chalmers 200 tractor from my father-in-law who left it set in the back 40 for years.  I drug it to my shop and started playing with it here and there and have been slowly trying to fix things that don't work.  On to my problem...The headlight switch was bad and someone pulled all the wires off it trying to troubleshoot itDead..I bought a new switch and can get the lights to work, however,  the way it works I don't believe is right.  Does anyone out there have a wiring diagram for this switch, my I&T manual is marginal at best and doesn't show the switch very well(or at all).  Any help you guys give is appreciated!  Thanks in advance!
Jared
Edited by JMB984 - 16 Jan 2017 at 9:13pm
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 9:09pm
Sorry I can't help you with your wiring issue, but I have to ask : Just how nice is this tractor, because it is probably around 45 years old, and if it's been sitting for 40 years, that would mean it only has about 5 years of use on it. I don't own a 200, but from what I hear about em, I desperately want one. Darrel
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 9:14pm
I read it that way first as well, but it says it's been in sitting in the back 40 for years, not sitting for 40 years.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 9:18pm
The owner's manual (not I&T) has a wiring diagram at the back.  That should be able to help you out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JMB984 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 9:21pm
Thanks for your reply Darrel.  I don't really know much about the history.  it was sitting in the pasture before my wife and I got together in 2007.  it was parked because the brake spring broke and one brake kept locking up! then the reverse shift fork got broke ram-jamming the trans trying to unstick the brakes.  I got it, put a starter on it, cleaned the fuel tank, repaired a fuel line, and have slowly been un-cobbling everyone elses "fixes".  the hour meter shows around 3k hours but the father-in-law couldn't say if it worked when he got it or not.  he bought it in the 80s, was the discing tractor for a few years till he found a 400 loader to put on it, and it's been a loader tractor since.  it starts and runs good but smokes pretty bad (fuel...think injectors need rebuilt).  typical farmer loader tractor....every panel is dented and lights broke out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JMB984 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 9:30pm
Wow, a lot happened while I was typing that novel! thanks for the replies, I guess I need to break down and buy a manual, is there any place better or worse to look for this stuff?
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 10:44pm
Look on line get a factory Manuel. My 200 came with a non factory book, it is crap compared to the factory Manuel.
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 10:51pm
Go to AGCO Parts Book and order one. They are very reasonable.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 7:50am
What about the light switch and wires makes you think something is still not right?
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 8:03am
Do yourself a favor and cut the resistor coil off the back of the switch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 9:27am
Please explain the benefits of cutting the coil off. I need to rewire two tractors.
Edited by lowell66dart - 17 Jan 2017 at 9:28am
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 9:41am
I just put a new switch on my 190 that has this
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote JMB984 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 12:24pm
The switch doesn't change continuity between low and high beams. The same terminals have 12v on low as well as high , the new switch looks like the old one, can't compare continuity since the switch was open on all terminals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JMB984 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 12:26pm
BTW, I ordered a set of manuals from AGCOPUBS all 3 for less than $75. Thanks for that tip!
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 2:26pm
I think my three were around that for my 175. AGCO does us right on the books for sure.
John D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John D Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 4:45pm
I have a 200 manual and could send pictures of the wiring diagrams.
1964 D17 series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote JMB984 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 4:49pm
That would get me by in the mean time! I would greatly appreciate that effort.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John D Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 8:17am
Cab wiring:
1964 D17 series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 8:35am
The resistor coil is used to obtain "low beam" on the first position, and also glows a dull red hot and will melt insulation if it happens to touch it.  This will make the first position flashers only instead of low beam and flashers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JMB984 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 2:17pm
This helps A BUNCH, however; my machine is an early serial number machine with two headlights on each fender. This gets me in the ballpark, and is a much better starting point than I had before
