hd 6 brake adjusting
kinghunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Topic: hd 6 brake adjusting
    Posted: 14 Jan 2017 at 7:02pm
need some help. right break needs adjusted. ive been told i have to adjust bottom and top, that the bolt sticking out bottom adjust bottom band. so do i just crank both down then back them off a quarter turn? just curious how to do it. dozer has brand new pads in it from previous owner but right side doesnt lock up like left side.
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2017 at 8:20pm
per the book, the brakes should have 1-3/4 to 2" of free travel at the pedal. adjust the top adjuster until tight then back off 2 turns then loosen the jamb nut on the bottom bolt and tighten bolt until brake band contacts drum then back out 1/2 turn. if needed, tighten the top again until about 2" free travel. too tight makes them heat up and too loose is what you have. I have found the bottom bolt gets frozen easily, I would put some never seize on the threads before turning the bolt into the housing. if this does not help, check to be sure there is no oil on the drums. good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 9:52am
thanks alot for reply. got ice storm last night will try next dry day.
This page was generated in 0.391 seconds.
