1300 Field Cultivator Shovels |
Mike Plotner
Joined: 02 Apr 2014 Location: Central Ohio Points: 1577 |
Topic: 1300 Field Cultivator ShovelsPosted: 14 Jan 2017 at 4:44pm |
Going to put new shovels on my 30 ft 1300 this spring. What does everyone like to run on theirs? Shoup has 6, 8 and 10 inch ones for sale. Current spacing is at 6 inches between the shanks.
Anyone ever spaced the shanks out a bit more, then ran bigger sweeps? I think this would help trash flow quite a bit |
2001 Gleaner R42, 1978 7060, 1977 7000, 1966 190 XT, 1966 D-17 Series IV and 1952 WD and more keep my farm running!
charlesbendal
Joined: 28 Nov 2015 Location: Fryburg, Pa Points: 92 |
Posted: 14 Jan 2017 at 5:11pm |
We have a 30ft Krause and we used to run the narrow roughly 2in wide ones you can flip. This year we switched to the 6in sweeps and they do a little better job. Our shank spacing might be slightly wider than yours.
DrAllis
Posted: 14 Jan 2017 at 6:20pm |
Get a 1400 Chisel-vator if you want 7 1/2" or 9" spacing (they were available both ways). Try and run any wider shovel than 6 inch and you will plug more often AND overload the shank bending it backwards in some soil conditions.
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 14 Jan 2017 at 6:41pm |
I always ran 6" on mine! thanks; ac fleet
Dans 7080
Posted: 15 Jan 2017 at 6:18am |
I had 6" on mine until I replaced them with used 9" ones. It is twice the machine now. Not to contradict the Dr, but the wider shovels reduced the plugging and it does a better job. I haven't broke a shank yet and its been that way 6 years.
Gerald J.
Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Posted: 15 Jan 2017 at 10:28am |
Some of the Shoup shovels have blunt curved edges, wont' cut until they get a few thousand acres of wear. The square nose is all that is sharpened. Lousy for cutting weeds. I mounted a set of them and after their failing to take out weeds I spent half a day under the field cultivator with an angle grinder putting a cutting edge on them. That is their Marathon I sweep. The other sweeps probably have a sharp leading edge but I've not bought them.
Gerald J. |
