190xt turbo?
j birke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j birke Quote  Post ReplyReply Direct Link To This Post Topic: 190xt turbo?
    Posted: 13 Jan 2017 at 7:58pm
Needing to replace my turbo on our 190 where do I go to get a match for it. I've gotten a high capacity and got one from a&i and both of them I have modify the tractor to fit.
25-40, WD-45, D14, D17D, D19G, D19G, D19D, D19D, 185, 190G, 190D, 200, 7000, 7060, and 8030
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2017 at 8:15pm
Do you have any numbers on your original turbo and a picture?
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2017 at 9:30pm
Is it a Thomas,ray-jay or aireaserch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2017 at 10:12pm
Go to a pump station, they have a replacement for your Raja-Thompson.    MACK
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2017 at 10:23pm
If your old turbo was a Rayjay, then you need to change the 2 oil lines.  I got a new A&I turbo and found lines in my local tractor wrecking yard.  No other modifications necessary.
Post Options Post Options   Thanks (0) Thanks(0)   Quote j birke Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 3:49pm
The turbo I have is a TRW model 37 of 70 serial 745 part 4020917
