Engine for a 918H.
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Engine for a 918H.
    Posted: 12 Jan 2017 at 2:32pm
I was wondering if anyone had the model and spec # for the Kohler Command 18HP engine that went in the Agco Allis 918H? I have one of the early TriAd engines that has expired. I would like to get a drop in engine for it. Mine is missing the model and spec decal. Thanks!
Bill(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 7:57pm
MODEL# CH 18 S    SPEC# 62513
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 7:59pm
Thank Bill!
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2017 at 4:46pm
That is the same engine that got put in my 917-h,-- and I wish they would have left the original 17 in it!---The 18 is a pain in the a$$ to work on.---engine has to come out to get to anything behind the shrouds! Good luck on yours! lol!  thanks; ac fleet
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2017 at 11:38pm
I like the command engines. They have a better lubrication system than the old cast-iron twins and are much lighter to move around when working on them. I will admit I really do like the sound of the cast-iron KT-twins in the older ACs.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2025 at 2:02pm
Tag on to this older conversation....I have a 918 AGCO that has a dead Kohler Triad...Have a couple of Vanguard 18hp and wonder where to get install/conversion kits.. Is this a viable way to go??  Or is rebuilding the Triad possible..Thanks....Dale
acken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acken Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2025 at 7:28pm
The early Triads usually died when they dropped a sleeve from overheating.
The overheating was commonly caused from valve cover leaking oil, then the grass/dust stuck to it plugging the fins. I don't know if any parts are available other than maybe used. You might try Small Engine Warehouse for components to repower with B&S Vanguard. Don't get rid of spacer under engine as that is needed for some repowers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2025 at 12:59am
I did check in with Small Engine Warehouse and they have a complete drop in with the plate and coupler ready to go...Think exhaust and one other thing to keep and reuse.  I have a couple of Vanguards and initially was looking for a repower with them if a kit is available....Thanks ...Dale
