Rear Blade
DanC911 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Topic: Rear Blade
    Posted: 12 Jan 2017 at 12:39pm
A while back some one posted some pics of a rear grader blade they outfitted with hydraulic cylinders for angle.  I'd appreciate it if you could repost or post a link to the page.
Thanks
Travis2766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 7:57pm
I would like to see a picture too!
190XT Series III, D17 Series IV, D15 Series II, All Crop 66, Rotobaler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 9:05pm
Someone did a great job on the project.  It could offset to pull snow out from under a trailer or overhang.  I think it also had a trip edge.
Ross D. View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2017 at 9:41am
Good morning. Is this the rear blade assembly that you wanted to see?   Ross.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2017 at 9:43am
YES!!!  Thank you for posting it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2017 at 10:36am
Did you have a video of the snowblower also?  If so, I'd like to see how you made it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2017 at 12:35pm
Hi Dan.   I believe that this unit belongs to 'nick51ca' from Zimmerman, MN.. What a beautiful combination. I hope it works really well. I would also be anxious to see more pictures of it in action. Perhaps nick51ca will see your Post and chime in on it. I noticed his Posts, with these pictures, were from Jan. 2015 +/-. I am hoping that he may have updated pictures, and or, a video.    Ross D.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2017 at 12:42pm
I found an old post of his:
Allied/Buhler/Farm King 66" blower mounted to the front of a CA.
Started by building a loader frame similar to the #8 using 2"x3" 11ga tubing.
21T #60 sprocket mounts to a PTO extender and drives a 1" 6' drive shaft. Supported by a bearing on each end and one in the middle. The rear sub frame connector extends all the way to the back and bolts to the rear of the rail, the middle bearing support is welded to it.
The three point bracket comes off these blowers, making it relatively easy to make your own mount. The direction is reversed via idlers, used 21T drive sprocket and #60 chain up front.
The gear box moved a bit just by pushing on the chain. Added the braces, right arrow, to fix this. This helped but it still moved so added a brace from the lower idler to the gear box, left arrow. These were the only mods to the actual blower, could bolt the three point mount back on and still use it that way.
I'll make a video when we get some decent snow again. Steers a bit hard when lifted and not moving but just fine if lowered or moving. No traction problems as long as there is no ice, and there are no weights or fluid right now. Uses live hydraulics that were added last year to control the chute.
Edited by nick51ca - Jan 07 2015 at 7:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2017 at 12:45pm
Here's the snowblower in action in action: https://youtu.be/zua6wrjB4ew
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2017 at 12:46pm
From an old post:
I didn't want to do the front mounted pump or electric option for what I wanted to do so this is what I came up with, hopefully it helps someone.
Used a mini Nippondenso alternator, it's small enough to fit under the hood. Pump was placed where the generator used to be, it has a double pulley.
Drilled and tapped the thermostat housing to add a mounting plate, used silicone to keep it from leaking. It's not shown in the picture above but there is also an L bracket from the thermostat bolt to the front of the alternator pivot bolt so the pivot is supported on both sides.
Top view of the tank, you can see the three brackets that were welded to it.
Parts List:
I figured this pump with the 3" pulley should give about 4gpm/1600psi @ 1650, the .517 cu. in. should be about 6gpm/1200psi. Running 2" cylinders the 4gpm seems plenty fast enough for me, not bad even at idle. The hoses are 3/4" suction, 1/2" return, and 3/8" pressure. When it got cold the hydraulics started slowing down and the belt slipping, switching to a low viscosity hy-tran solved that problem.
Finished product, the alternator is hidden under the hood.
Edited by nick51ca - Jan 05 2015 at 7:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2017 at 12:53pm
Made a rear snow blade that works well for clearing out the drifts under the edge of my trailer and getting into corners, or when there is just a dusting of snow. It's no wider than the tractor so it fits anywhere the tractor does but I can offset it or change angle. I have a good sized area that's sort of boxed in where the snow needs to be pulled, scooped, or blown out.
Edited by nick51ca - Jan 06 2015 at 2:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 3:49pm
Hi.   Maybe I missed it; but, was there a video of this machine in action?     Ross D.
nick51ca View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick51ca Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 5:11pm
Don't have any newer videos or pics but if you want to see something in particular just ask. Everything still works well and I'm especially happy with the blower.
The video link above doesn't seem to work, try this https://www.youtube.com/watch?v=zua6wrjB4ew
Edited by nick51ca - 16 Jan 2017 at 7:12pm
This page was generated in 0.143 seconds.
