Engine break in oil |
Page 12> |
| Author | |||
7060
Joined: 16 Sep 2009 Location: Missouri Points: 1148 |
Topic: Engine break in oilPosted: 11 Jan 2017 at 8:39pm |
I just rebuilt the engine in my 185 and overfilled it slightly with Rotella and put a pint of Lucas in it to keep from scoring a piston maybe. I'm thinking I should probably drain it out though and put some break in oil in to help with ring seating. Ive ran it long enough to circulate antifreeze though it but haven't took it out yet. What's the best break in oil to go back in it?
| Sponsored Links | |||
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 11 Jan 2017 at 8:52pm |
This has been discussed here before I personally wouldn't worry about it. I didn't use any in my d15 gas just normal engine oil. I thing the general response in here was how you run the motor is more important then the oil.
cottonpatch
Posted: 11 Jan 2017 at 9:09pm |
Being its winter and it's a fresh rebuild, I would opt for any diesel oil (rotella, delvac or delo) preferably in 10w-30 weight NOT 15W-40. |
'52 CA, '61 D10 II, ‘61 D15, '66 D15II, '63 D17D III, ‘69 170, '73 185 Crop Hustler, '79 185, '79 7000, '77 7040
MACK
Posted: 11 Jan 2017 at 9:36pm |
Put the oil you intend to use in it WITH OUT the
Lucas. Any additives like Lucas will prevent ring brake in. A cheap motor oil would be better the first 50 hrs than a good motor oil with additives. MACK
DougS
Posted: 12 Jan 2017 at 4:46am |
With today's oils an additive is not needed. In some cases they do more harm than good.
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3086 |
Posted: 12 Jan 2017 at 8:11am |
You can buy John Deere break-in oil from a dealer. Basically just poor oil to help the rings wear in.
7060
Posted: 12 Jan 2017 at 9:04am |
My thoughts with the Lucas was that it would keep the cylinder walls lubed up a little more to keep from scoring a piston when I'm working it hard. I will drain it and maybe try the John Deere break in oil. I know some people that use it.
DrAllis
Posted: 12 Jan 2017 at 9:07am |
10W-30 NOT synthetic car engine oil for 50 hrs.......not diesel oil, car oil.
Bill_MN
Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Posted: 12 Jan 2017 at 9:24am |
royal purple break-in oil, and NO additives of any kind
Edited by Bill_MN - 12 Jan 2017 at 9:25am |
BenGiBoy
Joined: 11 Nov 2015 Location: Ashville, NY Points: 705 |
AMSOIL makes break-in oil, if you want to go that route. Only 8.45 a quart.
AMSOIL Break-In Oil
'39 Model B
Tractors are cheaper than girls, remember that! |
DougS
Posted: 12 Jan 2017 at 9:30am |
Sayyyyyyyy.. it has that nasty zinc in it, too. :) It's oil without friction modifiers, as I suspected. Many motorcycle oils are also without friction modifiers. As for additives: Buy the right oil in the first place and avoid additives. Most are just snake oil treatments. Even my car owners manual tells me in no uncertain terms to not use oil additives. Edited by DougS - 12 Jan 2017 at 9:34am |
BenGiBoy
Posted: 12 Jan 2017 at 9:34am |
I thought that older tractor engines needed zinc?
'39 Model B
Dan73
Posted: 12 Jan 2017 at 9:38am |
Flat tappers need zinc but this is about the best way to get the rings to cut into the cylinders during the first 50 hours not what is best long term oil for the tractor. I am in the camp of just run it easy for the first 50 hours with normal oil. Worked on my d15 and I have used that 160 for all it is worth since 1 year of hard farming later runs great. Time will tell how long it lasts.
Edited by Dan73 - 12 Jan 2017 at 9:38am |
BenGiBoy
Posted: 12 Jan 2017 at 9:40am |
So they need zinc, but not in their break-in oil?
'39 Model B
Dan73
Posted: 12 Jan 2017 at 9:48am |
Breakin oil is about causing the rings to ware into the cylinders zinc is a lubricant so if you want to focus faster engine ware to get the rings to "take a set" then you need less lubricant in the oil. As I said I am not a fan of break in oil. |
Bill Deppe/AC Salvag
Joined: 12 Sep 2009 Location: Maquoketa, Iowa Points: 974 |
Posted: 12 Jan 2017 at 9:49am |
Long time ago an old experienced mechanic advised me to use a 10w or 20w non detergent oil and run for a short time without load as this readily seats the rings
Bill_MN
Posted: 12 Jan 2017 at 9:50am |
Actually, zinc and phosphorus in break-in oil has long-term benefits. As the metal parts wear in together and those microscopic rough spots in metal smooth out, the zinc and phos get incorporated into and coat the wear surfaces which remains once the break-in oil is drained. This helps with wear going forward.
Dan73
Posted: 12 Jan 2017 at 9:51am |
Bill I think at the time that was good advice but I thing rings and cylinders have come along ways over the years and it just isn't needed any more. But I far from an expert.
BenGiBoy
Posted: 12 Jan 2017 at 9:54am |
Thanks Dan73, that cleared up some confusion....
'39 Model B
DougS
Posted: 12 Jan 2017 at 9:58am |
Back in the late 50s Chevrolet told those who bought a car with a 265 V-8 to slowly pour Bon Ami down the air intake to break in the rings. Of course that was when you traded cars every two years anyway. |
Gerald J.
Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Posted: 12 Jan 2017 at 10:13am |
Over the decades breaking procedures have changed. Up until the late 60s Deere suggested a break in oil with Bonne Ami added and to work the tractor as hard as possible. When they changed to chrome rings they left out the abrasive and still worked the engine hard.
In 1973 with a new Ford Pinto (woody wagon) the manual emphasized during the first 500 or 1000 miles varying the engine speed for breaking and not working it hard. That's probably because the rod bearing peak wear point depends on the engine speed and load. Gerald J. |
Allis dave
Posted: 12 Jan 2017 at 11:08am |
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 12 Jan 2017 at 12:13pm |
Ben, Doug was being sarcastic........meaning it is GOOD, not nasty..... |
DrAllis
Posted: 12 Jan 2017 at 12:14pm |
I toured the Harvey engine plant back in August of 1980. Engines were connected to a dyno (multiple dyno's and multiple engines in one room) and engine was fired up. Oil pressure was verified. Oil leaks were looked for. I suppose it was allowed to reach operating temps and THEN THEY POURED THE COALS TO IT!! engines were under full load minutes after fire up, and I doubt very much any special oil was used.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5155 |
Posted: 12 Jan 2017 at 12:27pm |
oil of today is much better than even just 5 years ago. The break in oil allows a small amount of wear to occur on the rings/cylinders. Modern oil is too good, and the rings may have a hard time seating. Like Dr Allis says, I'm ok with running it for a few minutes, to ensure it's ok, then work it hard for a few minutes, then cool down, and repeat. My pulling engine, and drag cars get broken in with hard use right out of the gate. I am trying the JD break in oil for the first time on an Oliver I'm putting back together. It will not get worked very hard, so I want it to get broken in right. I want to put it on the dyno for a while also.
randy
Joined: 12 Sep 2009 Location: Illinois Points: 1226 |
Posted: 12 Jan 2017 at 12:38pm |
John Deere puts 10w 30 break-in oil in all of its new engines, so a JD service manager told me. I think they want it in an engine for about 200 hr, then go to there regular oil.
TimNearFortWorth
Posted: 12 Jan 2017 at 1:16pm |
Although oils have been changing constantly in the last 5-10 years, changes were implemented in 2016 by manufacturers so as to meet new standards set out to take effect by uncle sam this past December (Sulphur/zinc). I will continue with T1 Rotella from Wally World in my gas units as it is economical and a decent basic oil. Per my machinist who built the last gas engine I had done, he runs 4 oz. of Lucas TB Zinc Plus in everything he builds as a break-in supplement (every day rebuilds up to his own alcohol pulling engines) and advised he has done it this way for years.
When asked specifically if he would recommend any type of zinc additive on older flat tappet units, he advised 4 oz. in every oil change is what he is recommending to his customers. Take it for what it's worth . . . . |
DougS
Posted: 13 Jan 2017 at 11:32am |
You might want to read this before you just start dumping zinc into your motor oil:
http://www.drivenracingoil.com/news/dro/training-center/articles/zinc-in-motor-oil/ If I wanted zinc in my oil I'd buy oil that already has zinc in the formulation. Make note of what the author says about break-in oils and zinc Edited by DougS - 13 Jan 2017 at 11:33am |
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 13 Jan 2017 at 12:40pm |
That article made perfect sense until they gave the sales pitch at the end for Joe Gibbs assembly lube and oil. But what I did take from that article is that unless it's a high performance engine you can use regular oil off the shelf for break in and normal use and you will be just fine.
1957 WD45 dad's first AC
1968 one-seventy 1956 F40 Ferguson |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 89237 |
Posted: 13 Jan 2017 at 3:18pm |
BINGO - Stan.
Page 12> |
