520 grainhead repair question
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Topic: 520 grainhead repair question
    Posted: 10 Jan 2017 at 9:05pm
I need to replace a portion of the floor in my grainhead.   What is involved in removing the feed auger to get better access.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2017 at 12:14am
I believe if you just remove the adjustment and drive flanges, it should wiggle out. be careful not to bent the sides of the header as that will make it wobble while running it again, and cause stress cracks on the head. about a 2 person job with the aid of a loader. not hard, just bulky. did the floor rust out, or did it tear on something? most of the time I've seen where others have just replaced with that slick PVC sheeting, but you'll hafta re-adjust the drum afterwards. (a lot less work)
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2017 at 7:01am
Wore thin probably can stick two fingers in the hole.
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2017 at 7:03am
Not much help but we have a 520 head for parts if you need any
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2017 at 7:36am
if there is just one hole, patch it from underneath with tin and a bronze weld. tack a few welds on the inside to keep the edges from rolling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2017 at 1:11pm
Ha! Watch that sheetmetal run for the hills when you touch it with a flame!!!
