Anyone ever put a rocking hub on a Gleaner?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: Anyone ever put a rocking hub on a Gleaner?
    Posted: 07 Jan 2017 at 12:43am
I like to know the pros and cons of JD and Gleaner combines, so I'm educated on both when I explain to people why Gleaner is better. I was reading over test results from a 8820 and a late L2, and I thought some things were funny- like how the 8820 used between 5.5 and 7.5 gallons of fuel/hour and the L2 only used 4.4! Lol!
I also got to wondering...I'd never plugged a cylinder until this summer, so I'd never given thought to it. The 8820 has a cylinder rocking hub where you can rock the cylinder with a pry bar. Why doesn't the Gleaner have anything like this?? It sure would beat having to lay on your back and dig straw out by hand, and having it all fall on you and in your face!
Also....I've never had to change cylinder/concave clearance on our L3, but the article makes it sound like it's the worst chore ever (next to unplugging the cylinder and re-setting the trap door). Is it really that bad? I'll be having to set it 2 times this summer/fall. For Milo and Canola.
Here are the articles, by the way, if any of you are interested.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 1:16am
my Gleaner "G" had that, where you could rock it back and forth!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 8:56am
Only plugged my F2 a few times and no rocking hub would have turned it.Raise cylinder and rock it with the chopper belt.The worst was green stem beans and weeds.Had to unbolt the concave door on that one.Never plugged the A2 because only ran 4 cyl bars in beans.It would eat anything you fed it.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 9:33am
Gleaners all have a feeder beater in front of their cylinder/concave threshing area. The feeder beater is a unique gleaner innovation consisting of a fingered drum that segments the incoming crop into better even feeding to cylinder. Deere doesn't have it.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 12:48pm
IH and DEERE had "cylinder rocking wrenches" one STILL had to pull out the slug 90% of the time.  I had rather pop the door (probably popped anyway due to slug) and insert door tool in the cylinder bar and pry out the slug or chunk and relatch and go back to combining than gain access to the others hard to get to cylinder.  Ran them for over 40 years now and probably didn't  plug a cylinder 4 times...now the feeder beater - that's a different story... but it usually kept the cylinder from plugging.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 1:43pm
My problem when I slugged was the door didn't pop, slip clutches just went off. I opened the door, then had to dig for about 10 minutes before I finally got to the cylinder. Once it was cleaned out some, I let the engine run just a hair above idle, then kicked the separator in. It stalled the engine. Back to digging....
Also...Steve's comment made me remember again...it said the cylinder is hard to raise up and down on the L2. I thought it just had draw bolts? That doesn't sound too hard to me.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 4:11pm
no, the concave adjustment is not hard at all. loosen the two clamp bolts per side,  then level it with the drawbolt, one on each side. if bolts are anti-seized, it is only a few minutes.
To unplug the cylinder, I loosen the clamp bolts and just the nut on the bottom side of the drawbolt, leaving the top nuts alone so height goes back to the setting after the unplug, and loosen the bottom nuts an inch or so, and attempt to unplug with power.
Only the nastiest greenest crap will require more. Dropping the door and using the drawbolt top nuts to suck it up will almost allways get it.
I personally like leaving the feeder beater not clamped all the way down with all the springs so I stand a chance of plugging it instead, as unplugging it is better than unplugging the cylinder. :)
Other brands do have a little easier to adjust concave, but IMO there is alot more going for a Gleaner to make up for that one little negative.
Consider getting a PFP Enclosed cylinder, I hear they are darn near impossible to plug.
As far as comparing the two, keep in mind a L2 is supposed to be around a 7720 size, although I hear guys claim their L2 would hog with a 8820 and have less loss.
The secret of the Gleaner conventional is the down front cylinder, it minimizes rock damage, and starts the separation process very early. It also has a constant feed angle to the cylinder (header floor and feederhouse floor never change angle to cylinder, unlike ones with cylinder behind the feederhouse.
The walkers on a the L/M series are very long, and perfect for small grains, and walker loss is basically impossible. we hog 100-150 bushel barley through them cutting on the ground taking all of the 3-4 foot tall straw in, and never give a second thought to it.
The complete lack of gearboxes or other complex drive systems on the Gleaner conventional is another appeal, as is the centered chassis with the rear engine, which applies existing weight for counterweight as well as simplify the drives and make everything easier to work on.
They were years ahead of most of their competitors by bringing electro-hydraulics to the combine market, and the cabs were always as good or better than competitors with good ergonomics. Gleaner had seat suspension optional since about 68, and standard since 78, took JD till 1995 IIRC.
The rotaries share similar virtues such as simplicity, rear mounted engine, low center of gravity, and constant feed angle to the cylinder. What makes them special is the accelerator rolls, which do the pre-cleaning and also allow the cleaning system to defy gravity.
On both of them, they always have sported massive bins, robust undercarriage and drivetrain, and powerful engines, usually surpassing those of their competitors.
In fact, it was not till fall of 2011 that John Deere finally made a bigger factory grain bin than a 1979 Gleaner N7.
Basically the major downside to them is the dealer network. Gleaner had an excellent presence in the 70s and 80s, but thanks to parent company failures and mergers, dealers have dropped all over. Luckily Agco has done a great job for providing parts, even for the older models.
Thanks to the late Kevin Bien, the Gleaner brand has a promising future and has had a major revival over the past decade.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 5:50pm
Newer Gleaner have a feeder house reverse.   Used it frequently on the R52. I think the right person could make one for a earlier combine. Back when we had the K we had homemade tool to grab one of the pulleys. Before we made the tool used a pipe wrench not ideal but worked.
skateboarder68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skateboarder68 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 6:37pm
I remember how surprised I was when a friend was talking about changing sprockets on his red corn head (had a 1660 I think). I asked him if they were wearing out fast or why would you do that. He cocked his head and said "Don't you ever change the corn head speed?" I said sure do, I push a button!! Have since our 76 M. Maybe before then even
Orange & Silver still earnin their keep on the farm: R62, Series IV D17 nf, 185, 6080, 6080 fwa, 220, 1968 D21, 7045, DT240.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skateboarder68 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 6:50pm
Also one thing I loved about our L2 was the self-raising and lowering bin extension. Pretty ingenious I thought
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 6:53pm
x2! The grain cart guy always knows who's about full! Plus, like you, I just think they're ingenious. Just wish there were some flaps on the sides.
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 9:16pm
    Creston, Gleaner prides it self for weighting than the competition, less field compaction .
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 12:43am
JD 8820 combine (base machine, no headers) weighs 23,600lbs.
Gleaner L3 combine (base machine, no headers) weighs 14.300lbs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2017 at 12:14am
you know what is scary? It was not until the AFX8010 CIH Axial Flow that they finally got a VS feederhouse.
I think that was around 05?
Gleaner had it since 71 or 72. :)
Mike Plotner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Plotner Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2017 at 4:53pm
changing the concave clearance is kind of inconvenient sometimes, but not too bad. just have to make sure the little steel measuring tapes are correct so the cylinder sits level.
I have probably only plugged the cylinder 4 or 5 times since I've owned my L2, but I can tell you about every single way you can unplug a feeder beater. especially after I got that 20 ft head this fall!
2001 Gleaner R42, 1978 7060, 1977 7000, 1966 190 XT, 1966 D-17 Series IV and 1952 WD and more keep my farm running!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2017 at 7:31pm
I plugged the beater on my F2 first season too many painful times to remember.After shimming clutch "by the book",raising it and setting finger position and adding the rest of the springs,it hasn't happened again.
