B engine oil pressure?
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: B engine oil pressure?
    Posted: 06 Jan 2017 at 9:46pm
Any ideas of what to check for on oil pressure? Engine runs but no oil is coming to head. Gauge isn't reading anything but there is lots of oil in the filter. I tried to take the line loose that conmes out of oil pump to oil filter base and primed it with some squirts of oil from the oil can. Still nothing. Ideas?
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 9:59pm
the pump pushes oil thru the cam shaft lubes the crank and rods......... at the same time 15% of the oil goes thru the filter and is drained back to sump.. Take the filter off and see if it is packed full of a cotton material... see that there is a 1/4 inch diameter steel tube up the center of the filter... see that the tube has a very small hole in the end to bleed oil into the filter...... if the filter is bad, the tube is gone, or the hole is oversize, you can leak off 40% of the oil flow to sump and have no pressure inside the motor to bearings........ You could also have worn out bearings inside on the crank or cam that are causing loss of pressure................. pull the filter and tell us what you see.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 10:07pm
I cant tell from the photos on the other post, but who made the filter ?  Does it have a paper element inside or cotton rag type element ?
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 10:10pm
Filter isn't great but didnt want to put a new filter on a trash engine
Can't fix stupid
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 10:15pm
Oil filter is a Napa 1101 Gold Series filter. Filter looks like this one inside.
Yes there is a stem in the filter base.
There is a holes at the top of that tube. One at the very top and two smaller ones on the sides just below the tip.
Edited by AJ - 06 Jan 2017 at 10:16pm
Can't fix stupid
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 4:53am
actually Got ahold of NAPA wgo sent an engineer out. I showed them what was happening using my old filter and their new filter. The engineer then installed a 2nd new NAPA with same results. In meantime I had purchased a new filter from Steve at B&B, {actually six, he had em on sale},anyway, he tried to convince me it was OK and would cause no problem. I said if he were to put that in writing and guarantee in writing they would rebuild or replace engine if I ran it that way and engine blew, I would run his oil filter. He could not do it. Took all information and went home. I even provided him my new old oil filter I refused to use, along with my old original filter. It took a couple months but NAPA contacted me and thanked me for the help. They reverted back to the original style filter and even paid me back for the original filter I had purchased. All the old new style filters they had made were supposed to be returned by dealers and the good ones replaced them. Some dealers weren't very consciensious so sme escaped the recall. Looks like you got one of them.
Dick L View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 7:34am
With the filter off put a hose on the stand pipe with the end in a pail and start the engine. If you have oil then remove the stud that holds the rocker arms next to the gas tank and check for a groove in the stud.  While the stud is out blow air in at the tee or elbow where oil would enter the head to make sure the passage is not plugged.  If the stud does not have the groove it is more than likely in one of the other hold down places.
You do need a proper filter first though.
Edited by Dick L - 07 Jan 2017 at 7:41am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 7:57am
To see if the filter is the cause not having pressure on the gage and still have oil flow would be to plug off the stand pipe. If you don't have fittings to plug the line going to the filter base you can use a hose clamps on a hose over the stand pipe and plug the hose with a bolt and hose clamp.
It could be a plugged gage also if oil was let go for years and not changed.  Some  automotive gages will not show oil pressure on these engines.
Things to think about.
Edited by Dick L - 07 Jan 2017 at 7:58am
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 8:31am
Dick L wins my vote for "experienced based tricks of the trade"! Thinking I'm going to fly you in to look over and fix up one of my tractors!
D17 Series 1
Allis B- 1939
Allis B- 1945
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 8:57am
Read BOBS post........... you have a JUNK FILTER.... It will not work... PLug the stand tube as Dick said and see if that helps or you have additional problems.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 9:09am
So the dumb a$$'s at NAPA are back to listing that filter for the older Allis Chalmers tractors, man we had the same trouble with that filter years ago and now it's back!
AJ, I'd Take that crappie FILTER BACK and get your money back, it was the trouble with oil pressure on old AC's before and please not again! JUNK JUNK JUNK!!!!!!!!!
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 9:23am
Sounds like NAPA did not destroy the bad filters from a few years ago and came across them in the warehouse and said what the heck lets see if we can sell them. Leon
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 9:24am
Oil seems to be getting to filter but not to lifters. The gauge is off a running all C engine. It works on that engine. It is an Allis gauge
Can't fix stupid
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 9:36am
    Hey Dick L,,,,since you mentioned the groove on the rocker arm stand next to gas tank,,,it got me to wonderin bout something,,,,, Is there susspossed to be similar situation (groove) on the D14 149 engines,,,?? If I remember right,,mine had studs in head with washers and nuts on the 4 stands,,,but don't remember a groove,,,,???
 This engine has never had much oil goin to rocker arms,,but I guess just enough to keep em from siezing,,,???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 9:58am
(Seems) is really not enough! The only way to know is to (see) it for yourself. No way I can see it for you from here, all I can do is tell you how you can see it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 10:39am
Joe, Your rocker arm oil should come in at the center of your head. Just inside the gasket area a tube would connect to the center of the rocker arm assembly.   The tube would connect to a hole drilled between the center outside head bolt and the gasket sealing area. No studs involved.   As I remember! Look on the spark plug side of your engine and you should see where the oil line enters the head.
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 11:28am
Do not use that filter Fram c159 is what you need !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 5:24pm
You need the cotton style filter. Think about what's going on like this. You're standing in the shower and your wife turns the water on in the sink. Notice how the water pressure drops? That's what's going on with that paper filter you have. It allows too much flow so the pressure is reduced to the point you're not getting flow to the rockers. The cotton filter doesn't allow oil flow through it as easily as the paper does. More resistance to flow means more pressure.
oldways View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 11:04pm
When I bought my b it had low oil pressure and an old filter. I pulled the pan and the filter had come apart and made its way to the pick up screen and completely clogged it up. I'm not sure how it had any oil pressure. Looked like wet shredded newspaper.
Edited by oldways - 07 Jan 2017 at 11:04pm
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 11:31pm
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 11:32pm
Those filters should have all been destroyed!  It's why I still can't trust wix filters.  What is funny is that a few AGCO filters appeared at the same time with that design.  But they disappeared very quickly.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 7:37pm
Ok, put a correct filter on it (fram) and cranked it. No oil pressure on the gauge. Took filter back off, cranked again to see if oil if pumping. Oil does come out of tube well. Took rocker assembly off and like off on side of head. Blew air through it well.. Now what?
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 7:57pm
If you have flow you know you have oil moving thru the pump.  Flow should give some pressure. You need to prove you have pressure along with flow.
see if you can stop the oil flow from the stand pipe with your thumb over the  stand pipe. less mess if you use a piece of hose.  If you have flow and can stop the flow without spraying oil you have an oil pump problem.  If it sprays oil from under your thumb I would also remove the gage and see how much flow comes out of the fitting.  If the gage is good as you thought it might have had a solid that plugged the end of the gage when you screwed it in. A bug could do it.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 7:59pm
I think I got it now.
Can't fix stupid
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 8:11pm
Seems to have really good oil pressure now. Took it forever to start putting out oil at the rockers. I think the engine seems to have a little knock to it simular to a small diesel would. When I took the manifold of the other night I noticed there was alot of carbon built up on the valves in the head. Not sure if that could be a culprit or not. Can't tell where it coming from exactly.
Can't fix stupid
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 8:35pm
You could have lost prime which requires you to shoot oil from oil can down the oil pump exit tube.  If that solves it watch it and if it happens again you will meed to fix it. The cause will be the check valve (ball) in the rotor of the oil pump. Speaking from experience,
I have a B mower that lost oil pressure and I unknowingly ran it a couple of hours without oil pressure and now the motor knocks badly, so an overhaul is in order.Angry
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2017 at 4:42am
Looks like the oil may have some moisture in it, a like bit milky.
I would pressurize the cooling system and recheck for water, and change oil soon
Gary in Texas
Edited by Gary in Texas - 09 Jan 2017 at 4:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2017 at 5:55am
What Gary said.......I noticed the color in the picture right away!  Not a good thing.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2017 at 6:33am
It did have a little water in the bottom of the pan when I pushed it in the shop. Drained that and put in some used oil to check engine over to see if it was worth a darn before dumping brand new oil in.
The knock is what worries me.
Edited by AJ - 09 Jan 2017 at 6:34am
Can't fix stupid
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2017 at 6:58am
So what did you do to get oil pressure? Just running time?
