7040 hydrolics help needed
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Topic: 7040 hydrolics help needed
    Posted: 03 Jun 2010 at 9:13pm
any one know which direction the check valve goes in the rear tub im talking about the check valve that feeds the pump from the diffentral filters and and goes up to the pump? there is a two hole flange that has a flat shim/washer behind it then a rubber gromet behind it when compressed it seals around the tube to make a seal but between the pipe and housing there's a check valve stainless steel and plastic the stainless piece has two tangs do those tangs face the pump or the rear tub? thanks
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2010 at 7:08am
Check the Agco Parts website for a clear view of those parts. Hydraulic section-differential filter group.
