onan cckb
Tom IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IA Quote  Post ReplyReply Direct Link To This Post Topic: onan cckb
    Posted: 06 Jan 2017 at 1:46pm
I am working on a 620 the motor was bad I got a replacement cckb I think it was out of a 720 my old motor has the mechanical fuel on the top of the motor the replacement has a plate over the mounting hole did the 720 not use a mechanical pump ? if so I should be able to just move the pump to my new motor
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 2:00pm
Many folks have replaced the mechanical fuel pump with an electric fuel pump. In the process they remove and cap off the old mechanical pump.
One reason they do this is because the mechanical fuel pumps vapor locking when they are worked hard.
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
ac720nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 2:49pm
Mike also as parts are nonexistent for these fuel pumps.
