D14 hydraulic won't stay up
mike 44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Topic: D14 hydraulic won't stay up
    Posted: 05 Jan 2017 at 4:10pm
My lift arms keep falling down when I'm trying to push snow any suggestions? They won't stay up thanks
Edited by mike 44 - 06 Jan 2017 at 6:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2017 at 4:22pm
Eat more Spinach ???
Yes, I've got 2 that have that problem...
causes are
1) bad seal in rockshaft cylinder
2) bad hydraulic hose
3) bad check valve in hydraulic pump
1 and 2 require you to remove rockshaft and get 'inside'. Be SURE to pull BOTH plugs on belly...rear end(diff) will be FULL of oil, so put 5 gallon pail underneath AND have another nearby. Mine had 7 gallons in it....PTO shaft needs to come out(that's easy, but be real careful putting it back it or you'll destroy a shaft seal waaay inside the beast!
#3 is what I now have,means removing pump,cleaning it, replacing it.....maybe in the middle of summer......
I 'recycled' the lift oil for 3-4 years until I broke down and tore into it. Not a bad job,some things to know and be careful ,rockshaft is heavy !
Jay
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2017 at 4:52pm
Could be just pulling lever down too far.  If it is seals or hose it will run out of hydraulic oil pretty quick. How long will blade stay up with engine off?     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2017 at 10:22pm
It won't put the lever up and blade falls rite down
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 12:30pm
Put some synthetic Viagra oil in the system.
If that does not work, replace the oil with C-Allis.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 2:24pm
well....if the blade falls when you pull the lever up to raise, when does the arms lift?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 3:25pm
I pull lever up they raise but if I let go of it down they come unless I lock it they will stay all the way up
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 4:12pm
If your hydraulic and transmission oil levels stay OK, sounds like a bad hold valve on the pump.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 4:17pm
I was wonder about the seal in the cylinder but I would check the valve first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 6:45am
Thanks
