How do you fix this?
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: How do you fix this?
    Posted: 02 Jan 2017 at 10:14pm
Steering shaft out of my IB. It has some rough edges. Dont think thats gonna work. Does a regular B have the same as the IB?
Can't fix stupid
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 10:16pm
grind them down?
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 10:47pm
Originally posted by shameless (ne) shameless (ne) wrote:
grind them down?
How would that help? There are chunks missing from the edges, gonna be hell on the pivot shaft after I rebuild the steering box.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 10:55pm
oh....I didn't know it was missing iron, thoughts it was outward rough stuff!
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 5:48am
Parts book shows different numbers.  BUT...it looks like the only difference is the length.  I'm thinking you could buy one for a B with the gearbox you have and cut it down.  Would need a new key way milled in the steering wheel end.
AaronSEIA
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 5:50am
A pic would be nice so we could see what you are looking at
Wink
I am a Russian Bot
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 6:32am
Not sure why it didnt load the first time.
Can't fix stupid
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 6:37am
Ah ha, it's the worm gear that's chipped. I was thinking it was the actual shaft and couldn't see how that would affect anything unless it's at the seal area. I think you may be right looking for another shaft. I'm sure that one would work for a long time but it'll be sloppy at some points. I wonder if a good welding shop could repair it?
Wink
I am a Russian Bot
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 6:47am
I think I would grab a B gearshaft and cut it down.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 6:49am
Yea, that's what I'm hoping to avoid. Are the early B steering shafts the same worm groove?
Edited by AJ - 03 Jan 2017 at 6:50am
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 7:59am
I too was thinking what Lonn was
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 9:38am
Weld it up, get your dremel out, and grind it back down! I've fixed a lot of combine sprockets that way lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 6:06pm
I'm no expert, but b's and c's used one of 2 types, either Ross or Gemmer.  Take a look on the housing, to see who made it, then start your search...Lamp
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2017 at 2:18pm
AJ, new posting over on YT under "Discussions-Allis Chalmers" with a fella seeking info on an old truck with a ROSS shaft/bearings. May want to follow that post and see if anyone jumps on with parts source info as I find some good info over there sometimes.
You may get lucky . . . .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2017 at 5:50pm
What's YT?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2017 at 6:49pm
Yesterday'sTractors.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2017 at 7:53pm
Oh, OK I looked it up, miss kim selling chinese repro parts...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2017 at 9:37pm
there are two different gear boxes used on the B tractor, the Ross and the GEEMER.. They have different internals, but the complete box can be interchanged on the tractor.  The IB uses the same "Box", but the shaft is several inches shorter. Best way to make a B into an IB is to cut the shaft in half at the middle, remove the several inches, and slide each half back into a 1/2 inch piece of pipe about 4 inches long and  socket weld each end......... I have done this several times.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2017 at 9:58pm
The IB has a different rake to the box to accomidate for the short length from a regular B. I just need a good worm gear and I can do the rest.
Can't fix stupid
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2017 at 9:59pm
Mine is a Ross by the way
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2017 at 7:22am
AJ, are you in a hurry?  I took a Ross apart on my C, (1940) and changed it out because the pin was shot.  Swapped the whole thing out.  I have it up at the farm but I won't be going up for about a week.  I NEVER throw anything away, so I probably still have it.  I can look if you want.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2017 at 7:31am
Thanks Ted but the worm gear on a C is backwards to a B. I have several really nice C shafts with worm gears on them. The B ones seem to be hard to find. Not sure why since allis made 120,000 of these. You'd think they would be easier to find. I may be buying an NOS one from Paul.
Can't fix stupid
This page was generated in 0.219 seconds.
