160 suitcase weights
orange-is-power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange-is-power Quote  Post ReplyReply Direct Link To This Post Topic: 160 suitcase weights
    Posted: 31 Dec 2016 at 2:54pm
Are they unique to the 160 or will they also fit 175s/185s? Thanks.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 3:22pm
The slot is narrower on the 160 weights, but could be ground to fit.  Rick
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 6:19pm
The 160 lcg that I got had the same weights as my 175's. There may have been more than one style.
ALLIS EXPRESS!
This year:
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 9:39pm
The bracket on a 160 is thinner so original 160 or later wider slot 170, 175 style weights will fit.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2017 at 10:46am
I put on AM255444 suitcase weights, which I believe are the same as for the 170/175/180/185. They fit good. I also put the bar that holds them on through them. I was told these were the correct weights, but can't say for sure that is what came out with the one-sixty originally.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2017 at 12:20pm
The numbers that I had on the 160 weights were definitely different than those of 255444, which are off the 170/175/180/185/190. My 160 was an early one though, so had to be different, since the slots were narrower. Maybe the later 160's, like lowell66dart mentioned, were like those of the 170/175/180/185/190 then. It sounds right.   Rick
