Help with Roosa Master Injector Pump
McGatha185 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Topic: Help with Roosa Master Injector Pump
    Posted: 31 Dec 2016 at 3:50am
I need a bit of advice here. Please have mercy, before you get off on the kick about never rebuilding a fuel injection pump yourself, I absolutely, positively do not have the money, now or ever to send this in to get rebuilt. It's more important to feed my kids than feed money into this tractor, so it's either do this or start parting out the tractor. I have been very, very carefully disassembling this pump while my daughter films the whole thing closely with her fancy video equipment, just in case I need to reference back. I also have a rebuild manual but it can be vague at times and says nothing about how to get out stuck parts. The tractor has been sitting and, unknown to me, had lost it's fuel through a leaking priming pump, so now it won't start. I've found the problem. The plungers are stuck down. I think Ed suggested that this was probably going to be the problem in an earlier post. So my question is, how do I get them out? It's like they're glued. I don't want to get even remotely rough with this. I've soaked it in diesel and then in SeaFoam with no luck. I've got PB Blaster on it right now, but I doubt it'll work. Could I use hot water to loosen this up? How about soaking it in acetone? Thanks for any help!
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 4:57am
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 5:04am
Sorry, I can't get YouTube here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 5:08am
I can go over to the college on Tuesday when they reopen and see it there. Does it show how to manipulate out these stuck plungers?
Thanks for the help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 5:22am
try spraying stuck parts with Kroil...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 7:02am
Use a small hammer and punch and tap on them.     MACK
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 9:42am
Like Mack said, you have to tap them out very, very carefully, not to damage them or the bore. Get yourself a few cans of brakeleen. It will dissolve the varnish to clean parts up. You don't need penetrating oil because they aren't rusted in, they are gummed up. Dissolve all the varnish. Good luck, and just take your time to make sure everything is clean! Lube parts upon assembly with fresh clean diesel. Odd are, the delivery valve will be stuck too, so be sure to take everything apart and free it all up. Just getting the plungers free may cause more problems if you don't make sure the DV moves, as well as the transfer pressure regulator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 10:11am
Thanks guys. I'll work on this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 12:30pm
Ok, that worked great. A bit of break clean and then I lightly tapped it through. They came out nice. So, I've now disassembled everything except there is the delivery valve still stuck in the bore. I have it soaking in break cleaner now. Is there a good method of getting this part out? The manual mentions that it can stick and that a tool can be used to pull it out. I don't have the tool, so is there another way? Thanks again for all the help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 1:31pm
That worked great. I've disassembled the DV assembly and the delivery valve is stuck in the bottom. I've been soaking it with brake cleaner but it's not coming loose yet. It's the very last piece. Any suggestions? Thanks!
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 5:51pm
suggest going to church before installing the elastocast rubber washer you must replace...
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 6:36pm
Haha! I've heard that. The one in it looks brand new. It's tempting just to call it good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2017 at 8:24am
Ok, I got the DV out with a ground down set of forceps. Now to finish cleaning it up.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2017 at 3:19pm
Do not mix barrels and plungers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2017 at 3:34pm
That would make for a problem wouldn't it? Smile I just got the crazy washer replaced. It was a bunch of work. I couldn't get snap ring pliers to work at all. I ended up using two small screwdrivers like chopsticks.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 12:19am
Keep this up and you will be giving Ed competition!
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 8:09am
Or I'll hire him!!!! lol!
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 4:41pm
Oops, nope, I don't get any golds. This went back together a world easier than it came apart! But I had one problem... I went to Auto Zone and got an inch pounds torque wrench to make sure I put this pump back together to the specs in my manual. The governor bar was the first one that I had to set the wrench down really low (20 inch pounds). I was tightening this nut with ONE finger on the wrench and suddenly the end broke off. The wrench never broke over. I don't know if was me not seeing it, but I was being real careful or if the wrench didn't do it's job at that low a setting. Regardless, I need a new square governor pivot rod for a DBGFC pump. Anyone have a spare laying around I can buy?? Besides this the pump is completely assembled and ready to put back on the tractor. That the real test! Thanks all!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 7:54am
I machined a new governor pivot rod last night, so I don't need one now. Thanks for all your help!!
