6080 hydraulic prime |
Ericinecmn
Joined: 29 Nov 2013 Location: Princeton mn Points: 12 |
Topic: 6080 hydraulic primePosted: 30 Dec 2016 at 8:06pm |
Just changed hydro fluid in my 1983 6080 and both filters, filled the transmission and the rear end. My problem is it won't prime was working fine before just wanted to give it a little love and changed the fluid. This is my second time doing this and a don't recall this problem before. Any one have any thoughts on priming procedure?
Thanks |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5470 |
Posted: 30 Dec 2016 at 8:24pm |
Do the filters screw on upside down? If they do I always fill the filter full of fluid before I screw them on. Fluid change on my dads 6060 went well, so I am not sure what the problem maybe other than air in the suction tube maybe. I think it should be self priming but I am sure someone on the forum will know.
MACK
Posted: 30 Dec 2016 at 9:06pm |
Common on 6080 if you don't fill both filters with oil, especially the one's with two filters. MACK
Orange4ever
Joined: 01 Sep 2014 Location: Farmington, MO Points: 390 |
Posted: 31 Dec 2016 at 8:56am |
Far as I know there's no filter on the suction side of those tractor there's a screen down there in the block the safest thing to do is remove the pressure lines on the side of the pump use a vacuum cleaner to create a vacuum and pull the oil up into pump start the motor with the Lines lose at pump. run tractor see if you get oil pressure shut it off and tighten lines up. Don't run tractor too long. Did you clean the screen on the suction side?
If you want a man to be a successful farmer, give him a Allis Chalmers tractor. If you want him to be a successful mechanic, give him a John Deere
Ericinecmn
Posted: 31 Dec 2016 at 12:49pm |
Got it going this morning had to fill the filters twice and then it took. I topped it off and will let it sit for a day or so and make sure it does not lose it.
Thank you for the information |
lowell66dart
Joined: 10 Jul 2013 Location: Paulina La. Points: 964 |
Posted: 31 Dec 2016 at 9:55pm |
I have a new to me 6080. What brand filter did you use?
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Ericinecmn
Posted: 31 Dec 2016 at 11:36pm |
I have been using Agco hydro filters mostly, but when I change engine oil mid season I pick up a Wix filter at the local Auto Value store
lowell66dart
Posted: 01 Jan 2017 at 7:42am |
Thanks.
ssefick
Joined: 09 Feb 2022 Location: South Carolina Points: 139 |
Posted: 05 Jul 2024 at 2:47pm |
Late to game, but this happened to me today.
Filled filter, and filled pump through one of the lines on the top (toward driver). Hopefully works tomorrow. |
DrAllis
Posted: 05 Jul 2024 at 3:18pm |
Prime the pump from the top and immediately start the tractor. Don't wait.
ssefick
Posted: 05 Jul 2024 at 4:04pm |
Dr. Allis that is exactly what I did. Primed at the top, put everything back together, turned the wheel until flow through, cycled hydraulics, and everything works! Just wanted to post in case others search for this in the future.
Thanks all! |
