Need a snap coupler measurement
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Topic: Need a snap coupler measurement
    Posted: 30 Dec 2016 at 5:52pm
Anybody have a WD with lift arm latches installed handy? I am brainstorming and need to know how far apart the lift latches are.
If someone could measure how far apart the latches are, I would appreciate it.
Lets say as you are standing behind the tractor, measure from the middle of one latch to the middle of the other.
Thanks in advance.
Edited by littlemarv - 30 Dec 2016 at 6:50pm
The mechanic always wins.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 7:43pm
Measure from the center of one lift arm to the other. Should center the lift latches.
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2017 at 10:55am
If you are looking to clear something, you probably need to know inside the springs and rivet, which on my WD45 is 25". If you just want to know between the latches, it is 27 3/4". If a picture helps, let me know and I can get one as I have my blade mounted and ready for the snow.
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2017 at 4:37pm
30" center to center
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2017 at 5:43pm
Thanks for the help!
This page was generated in 0.289 seconds.
