What's in your oil or what's not in there.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Topic: What's in your oil or what's not in there.
    Posted: 29 Dec 2016 at 4:42pm
I read a post below that said something about Pennzoil is not good oil today and I thought I'd post a heads-up on today's oil and what's not it now, I'm not going to pick on one brand of oil but remember when Pennzoil had Z-7 on the front of the cans of oil, do you know what Z-7 was? for the guys that don't it was the zinc that was in oil to help flat tappet cams turn the lifters, and today thanks to the EPA they removed the zinc from oils build and all engines built today they use roller lifters and they don't turn like the oil flat lifers do. I'm not going to tell you what to put in your older engines, I'm saying to read-up on oils and what has zinc in your oil today. I had a good talk with my camshaft re-builder about the number of cam's that are wore out today and he said the new oils don't have zinc in them now and was firm not to just add a bottle zinc to your oil and he will not warranty a reground cam if it's not using the right oil to lube it. Again I'm not telling you what to do. And I'm not picking on "Pennzoil" just used it to show what was in the older oils back in the day.  Please read the oil you are going to buy and look for the word "ZINC" on it.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 6:06pm
And you'll be replacing the catalytic converter in your car within a year.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 6:25pm
Don Thanks for the info, do you think we should be adding something to the oil in our old tractors? I have one with a reground cam and would sleep better if I thot it was properly lubed.     Thanks   Mark
eighty nine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eighty nine Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 6:32pm
Good point on the no zinc. I think alot of the 15-40 diesel oils still contain some zinc. (Rotella states 1300ppm). We use that type oil in all of our older motors, gas & diesel both.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 6:45pm
My understanding was that the low zinc oils were mainly a problem for newly rebuilt flat tappet cam engines. This was a hot topic on the 'Hot Rod Power Tour' in 2007. I'm a Long Hauler running the full 7 days with the '69 Judge.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 6:47pm
Diesel oil can have zinc additive because the cam driven injectors need it. And diesel engines don't use catalytic converters.
Gerald J.
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 8:10pm
I've been told Shell Rotella 15-40 is the way to go.
The mechanic always wins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 8:16pm
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 9:37pm
Gerald J.
Hey whoah there my ole 99 power stroke had a cat on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 10:23pm
Now hold on guys I'm not saying what to use for oil, I'm just saying look at what you have been using and read what's it now has in it. I have been seeing more flat cams and cupped lifter faces in old tractor engines then ever and some of them are so bad they will not regrind and most of the older cams are hard to get and the costs are out the roof if you do find a new one.  It's hard to tell the owner of a 30+ year old tractor to buy some of the high dollar oils out there to just sit in an engine not being used daily.
Oils have been changing over the last 5 years and look at the Shell Rotella, I have been using it for years and it's been good for me, now Rotella T is blended in 6 diff mixes (I not talking about the weight) I'm not picking on Rotella oil, I'm saying just look at what you pick-up at the store now it might not be the same oil you got last time you picked it up. The old saying "oil is oil it comes out of the ground" is not going to save your older engines now. It's not what blend or who's mane is on the can, it's what's inside. I have gone back to using 30# break-in oil for rebuilds and have always used "CAT" cam lube on cams lobs and lifter faces.
My cam re-builder said the zinc additive in a can will not mix in the oil so I'm not going that way now just using break-in oil for start-up and short run-in's and changing to a good oil that owners can find local. I'm not going to say what you need to use, I'm not in oil sales. So you make the call on what go's inside your engines. lol
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 10:26pm
I've been told that Rotella T is not the way to go. I've always used and had success with Rotell T but I wonder. It was suggested to me to use oil with the car manufactures name on the jug plus their filters because the manufactures know what their engines need as far as lubrication and filtration is concerned. I do use Lucas with each change now.
LaJaMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 10:44pm
Could not resist putting in my 2 cents.  Some years back, I had an argument with some one on what oil was good.  Should have never done that, but .  Don't know much about what is in the different oils, but I currently have 2 vehicles and others in  the past that have gone 200,000 miles with no oil related problems.  Currently change oil at 5 to 6,000 miles.  I have been using Penzoil for at about 50 years.  NO PROBLEMS.  Going to continue.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 6:28am
If all else fails , READ the PRINT
nonetheless ,still dead.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 6:37am
That's like my wife telling me to stop for directions................... or me explaining to my wife which way East is on the map. LOL
Edited by Lonn - 30 Dec 2016 at 6:37am
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 6:50am
Gerald J.
Virtually all new smaller (automotive-sized) diesels do anymore. Use the API grade of oil your manufacturer specifies. I've always felt that "something better" isn't. If you want to go with a higher grade of oil, within that API spec, be my guest. Switching to synthetics is a good example of this.
Edited by DougS - 30 Dec 2016 at 6:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 6:53am
I think many miss the point. The argument is NOT what oil is good to put in your car that is 0- 20 years old.. ALL of the NEW OILS meet the NEW CAR SPEC.. Don't matter if you use Pennzoil, Mobil, or Wal Mart.. they are all GREAT for newer cars.
What DON is talking about is OLDER tractors and cars from the 1930- 1970 era.  The new oils are FAR SUPERIOR to older oils, EXCEPT for the zinc addative that was for cam shafts of the old design.  Many believe the newer oils without zinc are not a good idea for older motors. Personally I use Mobil 10-w30 in the older tractors and have no problem... BUT I only use them  50- 100 hours a year.  If I was farming with them or using  heavy loaded on a daily basis I might be more concerned. Right now, I am NOT.
BigBadAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigBadAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 7:42am
Oil threads always generate a lot of opinions and create hard feelings.  For current model engines, it's plain and simple.  Use an oil that meets the manufacturers specifications.  Use a good nationally branded oil like Mobil, Shell, Chevron etc.  There's some decent boutique oils like Amsoil, Royal Purple, Schaeffer's etc.  Stay away from cheap oil blenders and off name oils.
As far as higher zinc levels for older flat tappet engines, you can get properly blended and formulated oil with higher levels of zinc.  Typically they are marketed to the race market since they don't have cats.  You can find them in most well stocked parts stores.  Some might say non-street or off road (racing).
Oil formulations use different additives for anti-wear and a lot of the HD Diesel oils still have an adequate level of zinc and other additives to protect your engines.  If you're buying a good properly formulated oil, you DO NOT need to use an oil additive.  Some oil additives actually take away from the performance of the oil that you just installed.
Happy New Year
Jason
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 9:41am
Which Rotella? Shell calls all their diesel grade oils "Rotella." They have several different API types. With Rotella you have to know what you are buying. He's an example of where you want to be SURE you are using the correct oil. Go to their web page. You do NOT want to use an earlier API Rotella in a 2017 or newer diesel. Pay special attention to the CK-4/FA-4 differences.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 9:42am
Thanks Steve and Jason, that's what I was trying to get out to the guy with a older tractor like 175's and older with flat tappet cam's, I'm not talking about newer engines in your 2005 pickup with roller lifters. All I'm saying is just like Fred said read what's in that jug of oil you pick-up before you put it in your older tractor if you still work her.
OK here's the deal let's say you have a show tractor maybe it's a 1935 WC and all she see for work is the load-up and go to a show one or two times a year in a case like this a good brand of oil that no longer has zinc it will not wear the cam much if at all so use what you like, but let's say it's 170 that feeds hay all winter and works in the field all summer then I'd look at the oil used in it.
BenGiBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 10:36am
Okay, I am a tad confused here... Do I want zinz or not in my older tractor engine?
'39 Model B
Tractors are cheaper than girls, remember that!
ocharry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ocharry Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 10:40am
another thing is most if not all synthetic oils dont have any or very little zink in them
i did a lot of research on this when i bought a new generator,,,,i was going to run it with the oil supplied and then change to synthetic,,,,,wow,,got to looking and that isnt recommended,,,not much or any zink,,,,makes air cooled engine run hotter,,,not because of zink but just a trait of syn. oil,,,,doesnt take heat away as well as regular oil
so after i did some looking and reading i settled on valvoline racing oil,,it is easy to find and or order at autozone( they have it on the shelf ) or other auto parts stores,,ZR1,,IIRC,,it list the zink nos. on the bottle,,,and they are up there pretty good,,,yep it cost more,,,but it is cheaper than a overhaul or new cam and lifters.....this is just MY pick,,,read up about it and READ the label on the jug or bottle
the newer motors with roller lifters and rockers dont apply,,,ONLY FLAT TAPPET
thx Don,,,good topic
my .02
ocharry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 11:06am
Older flat tappet lifter engines need zinc.  Gas, LPG or Diesel.
Newer roller lifter engines do not need zinc.  Gas, LPG or Diesel.
I hope this helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigBadAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 1:09pm
my .02
ocharry
The Valvoline VR-1 Racing is a good choice.  Note that they have two versions if the VR-1 Racing.  They both have zinc but one is significantly higher than the other.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 1:25pm
Wrong. AMSOIL makes a type called Z-Max. It's a high quality pure synthetic oil that has zinc in it. It is marketed specifically for classic cars and racing. I'm sure other high end synthetic oil brands offer something similar. Just don't start getting the idea that this would be the greatest thing since sliced bread for your family car. Unless you enjoy driving with the check engine light on constantly after your converter goes south.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 3:58pm
Don said; "OLD TRACTORS"!!!!   We do NOT WANT ANY comparisons to new cars here.
THINGS MADE PRE 75
A couple of quotes:
AMSOIL makes a type called Z-Max. It's a high quality pure synthetic oil that has zinc in it. It is marketed specifically for classic cars and racing.  I will add ----------OLD TRACTORS---------
The Valvoline VR-1 Racing is a good choice.  Note that they have two versions if the VR-1 Racing.  They both have zinc but one is significantly higher than the other.  This one if for OLD TRACTORS TOO.........
Post Options Post Options   Thanks (0) Thanks(0)   Quote eighty nine Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 4:05pm
No need to over analyze on brands here. The op Don made a very good post stating to read the label as things have changed and what to look for. Each individual can decide from that advice what suits thier needs.
JD Dan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD Dan Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 6:27pm
Thanks Don!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 12:01am
Be careful about VR-1. It may have ZDDP in it, but it has little detergents in it because a racer isn't going to have it in his engine long before doing a tear down and rebuild.
allismanamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 3:26am
What oil do you use for a all around oil don I was buying 5w30 from napa and do light plowing and pulling Baler in the summer
Napa 5w30 have zinc you think?
~AMP~
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 5:49am
You hit the nail on the head. You need to consider everything when you buy oil. While zinc is nice for flat tappets, it isn't a wonder additive. To me detergency is more important. Also consider the hours you will be putting on your engine. Say you plan on using your engine for 100 hours a year. How much additional wear will you have without zinc? It will be insignificant. If engine wear means so much, consider synthetic oil. It does reduce wear. It does not have a sacrificial additive, but it does provide a better protective layers then the old oils of 50 years ago. If you feel good about using a certain product, then go with it. Just keep in mind that the oil industry reformulated their motor oils to have anti wear properties when zinc was phased out.
