N7 problem
Big Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Orange Quote  Post ReplyReply Direct Link To This Post Topic: N7 problem
    Posted: 28 Dec 2016 at 7:39am
My neighbors N7, grinds corn & splits beans bad. We have adjusted everything we can think of to fix the problem, but no change, what are we missing? HELP PLEASE
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 12:19pm
Could be multiple things on an old "P-1" processor. Reverse cylinder bars could be removed.......worn helical bars (doesn't take much wear to cause issues).....worn out cylinder bars on the thresher side.....worn or not level concave.......plugged concave........cyl speed in corn shouldn't be over 320 RPM.....maybe 600 in beans.......discharge paddles that are bent back instead of forward........accelerator rolls that are no timed properly ??
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 1:48pm
Is the concave set down to tight?
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 1:55pm
what do you have for accelerator roll drive? the early ones had roller chain and could be out of time, newer had gears, but they are adjustable so it could still be out of time.
Are you taking the cage covers off for corn?
What kind of rotor speed? Like said above, inspect bars, discharge paddles, concave, etc.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 9:36pm
Two speed gear box needs to be in low.    MACK
