180 Engine Heater |
Dave (NE)
Joined: 12 Sep 2009 Location: Eagle Nebraska Points: 2157 |
Topic: 180 Engine HeaterPosted: 26 Dec 2016 at 10:52am |
I have an Allis one-eighty diesel I acquired a few years ago. It has a block heater on it and also a heater connected to the water hoses. Why would there be two heaters on it? I have used the block heater, and it does heat the engine up. Just wondering if there is a reason to have both and to use one over the other. Thanks, Dave
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8753 |
Posted: 26 Dec 2016 at 10:57am |
usually tank heaters were used when no place for a block heater. Don't see advantage one over the other. Maybe a low watt block heater VS a 1500wt tank heater?
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3994 |
Posted: 26 Dec 2016 at 12:24pm |
bet at one time one whent bad and a differant one got installed and the old never got removed or the cord on the block heater whent bad and the other got put on until a new cord came or back up just thinking like some of my customers
Krazy Karl
Posted: 26 Dec 2016 at 7:49pm |
Could be an old timer that didn't like block heaters. 1 Reason I've heard was they thought would cause pitting on the two cylinders thats next to heater. 2 reason i heard tank heaters heat whole cooling system uniformly because they make coolant flow
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7574 |
Posted: 26 Dec 2016 at 8:11pm |
You would have to ask one of the previous owners. Some of them do pretty strange things... |
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 27 Dec 2016 at 3:59am |
maybe with both of them, they could get it heated quicker in the mornings , instead of having them on all night?
