Need thoughts on a 7020
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Topic: Need thoughts on a 7020
    Posted: 26 Dec 2016 at 10:52am
Hey all,
I am looking at a 7020 that apparently was a little bit of a basket case for the previous owner.
First he bought the tractor, then the engine went down. had the local to him Allis Dealer rebuild the engine, supposedly major inframe rebuild.
Then, the PTO went out, so he had the PTO rebuilt.
Then, the Power Director transmission quit, so he threw in the towel and parked it. Sat for 10 years plus outside (luckily in arid western KS, where 20 inches of precip is the supposed normal, but we usually get much less than that) and our tractor jockey buddy bought it. (reputable guy, will tell you everything he was told, we have bought 10+ allis' from him)
Also, it appears that early in life before the last owner bought it, the rear end might have been swapped? The only reason I wonder this is because there is no serial number on the rear end, perfectly flat and no signs of buffing, bare metal. I am thinking the dealer forgot to stamp the numbers in the new housing.
Going off the nice radius cut in the frame rail for the lift pump filter (only last year was factory installed LP), and the nov. or dec of 80 date on one of the engine castings, I am believing it to be a 81.
So, I ask you guys,
1) Why would the transmission quit pulling?
a) transmission dipstick is not showing, could it be as simple as a seal between hyd. pumps emptied the housing and with no oil, the PD clutch would not pull?
b)with an inframe major, could the rear seal have went out and puked oil on the torque limiter and caused it to slip?
c) what are the chances there is major transmission damage? will the PD quit pulling long before any bearings are starved of oil? Does it hurt the PD to run out of oil?
2) Is it common for replacement rear ends to not get stamped? I hope the tractor was never stolen in its life, but its perfectly smooth and square metal in the proper area, so I am hoping someone just forgot to stamp it.
3) Whats it worth? as-is, the guy wants 2 grand, so I am thinking of jumping on it. he has not heard it run though. it has 4 GY Dyna Torque II 18.4x38 bias tires at 60-70 percent, and is fairly optioned out, has the aux. fuel tank and long axles with 9 bolt duals, although I dont think it has Stadium lights. No weights.
Any info appreciated,
Thanks!
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 11:04am
Sounds to me, if I had 2k sitting around, I would already own it.
Just some initial thoughts, are a failed pump, possible torque limiter striped, input splines on the PD, any number of somewhat minor (IF you do your own work) problems.  Yes they could be involved repairs, but nothing earth shattering.
If the cab interior is in good shape, the sheet metal is decent, and no other signs of abuse, that is a good value there for the do it yourself'er!!!  For someone who has no choice but to take it to the dealer, it's a parts machine financially speaking anyway.
That is exactly how I like to buy them, so far I haven't been burned yet doing it that way!
Still in use:
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 11:52am
I think I'd get it, shoot ya could even spend a little on it to find what the problem is, if it looks like it will turn into a money pit, ya can prolly get most your money back parting it out. I'd think a good running engine would be worth at least $1500-2000, rear tires/with hub duals about the same...all the other parts would go in your pocket..but if its a simple fix, even if ya hafta split it, ya gots a $7500-10,000 workin machine
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 1:09pm
Thanks for the advice guys, I guess even at 500 apiece, the tires would pay for it.
Dont worry, no hiring anything done. I am too picky. Although we are believers of "Do it right or Dont do it at all" so there is alot of stuff sitting around not fixed, because time or money will not allow it to be done right. :)
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 7:42pm
Its most likely the torque limiter, being they did an inframe rebuild it would not have gotten replaced at that time. Do the hydraulics work?
If they do then its a problem with the PD, or low oil in the transmission. BTW it is very unusual for the PTO clutch to give trouble, almost unheard of unless really abused.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2016 at 1:06am
Kevin, This guy did alot of roadside mowing, anyway the PTO could be starved of oil on a steep slope?
I have not seen it run yet, so I cannot further diagnose it for now.
Correct me if I am wrong, but isnt there a seal between two of the pumps that if it were to fail, it would pump oil out of the transmission and into the rear end? I am hoping this is it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2016 at 10:38am
Yes, there is a seal between the gerotor and gear pump, it isn't real common but yes it can pump the transmission oil into the rear end. PTO clutch pressure comes from the piston pump so its not affected by the trans running low, as far as steep slopes, I doubt that would have caused any problems unless rear end was really low, and then he would have noticed the steering acting up also.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2016 at 3:33pm
thoughts,  unless under warranty, it would have cost more to replace the rear housing than the tractor was worth.... the pto's on 7000's were almost indestructible- something else strange,,,,,, 7020 engines were prone to electrolysis can believe the inframe - hope the sleeves were replaced..... PD clutch will quit w/o oil in the tranny - usually will not hurt the PD but a starving geroter pump will get damaged--- which is close to the seals... what is the width of the planetary rings?? Do they match the ring width of another 7020,7010 or 8010. ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 3:10am
OK, new info.
Our tractor jockey buddy decided to call the previous owner to do a little research to see specifically what might be wrong, and the guy who sold the tractor provided some new info that he had not shared prior.
Supposedly tranny is fine, but the tractor was parked because "It would not pull itself and would drive in circles"
The tractor seller has a slight alcohol problem, so that is why info is new and is suddenly remembered. :)
So I guess it could be rear end issues or something as simple as the steering spool?
THe wheels were pointed straight when he bought it, so I dont think he meant the steering hyd, but that is not out of the question.
What all could go wrong in the rear that would cause driving in circles?
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 7:03am
I've seen a couple time where alcohol fueled tractors tend to drive in circles...
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 11:59pm
what would happen if the differential carrier cut itself in half from the two pinions galling?
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2017 at 5:07am
That tractor in good shape would only bring about $4500 around here. Southeastern Indiana.
