7000 Series Power Steering Ram Rebuild?
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Topic: 7000 Series Power Steering Ram Rebuild?
    Posted: 26 Dec 2016 at 10:26am
Hey all,
We have a 7060 that needs the steering ram rebuilt and I was hoping I could get some advice on how to do it successfully.
I thought there was a post on it, but after many searches I cannot find it, so I figured I would start a new one.
First, how does it come apart, and second, any tips on sliding it back together so as not to cut anything or knock o-rings out of place?
We did get the Agco kit and it does come with a new nut.
Any info would be greatly appreciated,
Thanks!
Edited by GM Guy - 26 Dec 2016 at 10:27am
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 10:49am
Remove outer snap ring on the gland, tap the gland in to expose the retaining ring in the tube, remove it and pull the assembly out.
Polish the groove area of the tube and it will go back together easy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 10:52am
Very easy job....can't remember a thing about it.Book is out in shop.Parts book break down would probably show how to go about it.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 11:39am
I use a cylinder hone to smooth out the gland snap ring area, that seems to help a lot
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 4:08pm
Very easy job, did my 7020 cylinder this summer. Like they said remove outer ring, tap piece back in until inner retaining ring is exposed remove and pull assembly out. Just make sure all pieces are polished clean an no sharp edges upon assembly. Took me roughly an hour due to polishing up parts!
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 8:51pm
new nut in kit seemed cheesy compared to old one...I think I re-used old one with a little lock tite
Barrettj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barrettj Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2019 at 4:07pm
I have a 7020 that I'm attempting to remove steering cylinder to rebuild it. The 2 mounting bolts on either end of the cylinder appear to be stuck in the ball joint & won't come out. They will turn but ball joint turns to. Any thoughts on how to remove bolts?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2019 at 8:47pm
Sounds like the bolts are rusted in the ball joints.  Penetrating oil and maybe a little bit of heat...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barrettj Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2019 at 7:41am
I've been trying soak it with PB Blaster but its hard to get any where it needs to go. I'll try a little heat. Thanks for your input. Much appreciated.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2019 at 5:50pm
Maybe try a two jaw puller to push the bolt out?
