Engine opinions for 210 |
7060
Joined: 16 Sep 2009 Location: Missouri Points: 1148 |
Topic: Engine opinions for 210Posted: 23 Dec 2016 at 7:45pm |
I have a 210 with electrolysis that I'm going to be putting a different engine in. I like keeping things original, but I have a 3500 series block that I could do a full overhaul on. My other option I have is a low hour 3750 out of a n5 combine. My question is, what would it do to the value of the tractor if I went the 3750 route? I've been going back and forth so I would like some other opinions. I will probably paint the tractor afterwards.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8749 |
Posted: 23 Dec 2016 at 8:17pm |
Plan on selling?Plan on selling to a purest? Just gonna keep for your own use? I'd put the combine engine in it but that's me.I don't git rid of nothing.
210Postin
Joined: 06 Oct 2016 Location: Ellisville IL Points: 151 |
Posted: 23 Dec 2016 at 8:31pm |
I have put in later engines in 220s but if you were not a ac nut you would not have known.Electric tach water connections etc it is all about how you do it fast and easy will look like crap
BKarpel
Joined: 27 Apr 2012 Location: Collinsville IL Points: 113 |
Posted: 23 Dec 2016 at 9:17pm |
You could use the engine that's in your 210 and rebuild it that would keep it original and correct. We remove the sleeves and bore out the bottom of the block and install a repair sleeve. Then we push in new sleeves. This is a common problem and have repaired many AC blocks this way. Remember to install a coolant filter.
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3604 |
Posted: 23 Dec 2016 at 10:40pm |
I agree. After you rebuild your 3500, you'll know exactly what you have. Save the 3750 for something bigger like 7080, 7580... |
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4574 |
Posted: 24 Dec 2016 at 5:53am |
I'm kind of a purist and a hot rodder at the same time. Have a D-21 and 210 with original engines but my 220 has a newer 3500 MK II engine and I've changed the water pump and added an intercooler. It's my 220 XT that you may have seen in OAN.
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 24 Dec 2016 at 8:49am |
Usually what is the most practical for you works the best.
7060
Posted: 24 Dec 2016 at 9:03am |
I'm not sure if I'm going to sell it or not. I saved this tractor from going to the scrap. I didn't want to see it get parted out either because it was somebody's pride as they put a chrome stack and air cleaner on it and put a name on it. I've held onto this 3750 for 4 years now and just hate seeing it set in the shed with 1500 hours. But I think I'm going to continue with the plan on rebuilding the 3500.
Jordan(OH)
Joined: 11 Sep 2009 Location: Celina, OH Points: 1572 |
Posted: 24 Dec 2016 at 9:08am |
DrAllis
Posted: 24 Dec 2016 at 9:12am |
If it has 2-sleeve O-rings (which it probably does) just overhaul it and the new sleeves will have 3-Orings. Block will be OK.
SteveM C/IL
Posted: 24 Dec 2016 at 3:57pm |
HMMMM! I like Doc's answer
