190XT PTO lever
TexasWD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasWD45 Quote  Post ReplyReply Direct Link To This Post Topic: 190XT PTO lever
    Posted: 22 Dec 2016 at 3:47pm
My PTO lever sheered off! It broke close to the transmission so theirs no way to weld it back on. any ideas on how I replace it?
'38 B with belly sickle,'52 WD,'54 WD45,'39 WC,'47 B
ksbowman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 5:26pm
Can you drill it and tap it, then put a hardened bolt in it with a long thread. Then tack weld it. Then cut the unthreaded part off. Put a fabricated handle on it and tack weld the new handle to the all thread?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 10:27pm
Clean weld from lever, place lever over shaft and re weld. Have done a lot of them.   MACK
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2016 at 9:35pm
The heat would probably melt the O ring, then you would always have an oil leak there.  If you can take the tractor out of commission for a while, you can take the assembly out, fix it up and put a new O ring on it at the same time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasWD45 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2016 at 10:40am
How do you take the assembly out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2016 at 11:01am
Split the tractor where the torque tube meets the transmission.  Everything will be accessible after that.
