D17 Diesel Value
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Topic: D17 Diesel Value
    Posted: 21 Dec 2016 at 5:55pm
The guy said its supposed to run and turns over. I am not as well versed in the D17 diesel as the gas so what do you guys think it is worth?
The good:
Black Bar grill
Straight Sheet metal
Good original paint
factory 3-spool hyd valve by left fender
Has side panels
Water pump is on head
The Bad:
One shifter fork is broken, replacement included
power Director doesn't stay in High or Low
No power steering
No 3pt, just Snap Coupler
Fluid filled rear rims are OK
16.9-28 tires checked but average
www.awtractor.com
A&W TRACTOR 920-598-1287
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2016 at 8:36pm
What is your plan for the tractor? Hopefully Don in Montana will chime in he is an expert on these. But it is my understanding that the d17 diesel motor is very expensive to rebuild and most have major issues. Just going on what I have read on here. It seems to me people love them but they are considered more of a collectors tractor then a work tractor.
To fix the high low you will have to split the tractor I have done it in my d17 gas not too bad a job I don't remember the price of the clutches.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 1:54am
$3000 would buy any one like that one, that didn't need work. Start deducting from there for the labor involved to get it working again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 5:18am
Had to delete that one i was writing about a gas not diesel got my threads crossed.
Edited by Dan73 - 22 Dec 2016 at 5:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 11:36am
1000-1500. Yes they are very expensive to overhaul. I think it was Don Bradley that said you need $5K to go through a basket case. I would agree. I spent $3K on mine but was lucky that the head was in very good condition. Only the machine shop work was farmed out, I did the rest of it myself.
