Whiskey Throttle Vid
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Topic: Whiskey Throttle Vid
    Posted: 18 Dec 2016 at 8:05pm
seen this on you tube and thought I would share
Edited by Beirnesy - 26 Dec 2016 at 12:49pm
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2016 at 8:25pm
[TUBE]xAOOIk_fAvY[/TUBE]
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2016 at 9:13pm
Repowerd with cummins on alky
7040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2016 at 12:17pm
Green county machine built that 5.9 Cummings repower
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2016 at 7:57am
Does he use a 185 rear in that tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2016 at 8:47am
Yes from bell back it's orange
mf440 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mf440 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2016 at 3:10pm
From front of trans back lol. The bellhousing / power derector housing is missing has a clutch can
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2016 at 4:44pm
Who makes the clutch can??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2016 at 5:26pm
Really do tell on the parts needed since the PD is missing;
Post Options Post Options   Thanks (0) Thanks(0)   Quote mf440 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2016 at 5:37pm
clutch can/ SFI bellhousing , input shaft with an adapter to the transmission
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2016 at 5:59pm
Yes who makes an SFI clutch can for these?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mf440 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2016 at 8:26pm
Probell or any other manufacturers and any good machinist can make the rest of the parts needed to make it work.
Larry W. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry W. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 12:29pm
You can make most any bellhousing work, mopar or chevy steel bell housing and custom backer plate for the motor
Jerald/KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jerald/KS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2016 at 12:58pm
Whisky Throttle is our old Orange Crush light super. It was set up with with a re drilled rear plate and a Hemi clutch can, crower 3 disc clutch, chevy gear reduction starter, Pro Fab 2 speed, solid driveline and couplers to allis input shaft. All gears in allis trans removed. Ran a final gear ratio of 19-1.  Our second tractor Smokin Assets was set up the same, but even removed axle tubes and machined aluminum adapters to mount finals directly on rear end housing.
Acllss puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2017 at 8:14pm
How much ton build another set of aluminum adapters?
