190xt gasser wiring
tx091 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tx091 Quote  Post ReplyReply Direct Link To This Post Topic: 190xt gasser wiring
    Posted: 18 Dec 2016 at 4:25pm
What size wire do I need for the starting circuit from temp guage to switch and from switch to starter?
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2016 at 4:43pm
Temp gauge isn't critical. I would go with #18 or better because of the added strength. #14 would work to the starter solenoid, but again I'd go with #12 or even #10 because the wire is stronger.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2016 at 9:40pm
I think you mean starter to switch. 10-12 gauge. Switch to temp gauge. 14-16 gauge.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote tx091 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2016 at 7:15pm
Yup, Senelity setting in, I meant from the amp guage to the ignition, It has #8, I stayed with that. From the switch to the solenoid I went with #12. I disconnected the push button switch and ran right to the ignition switch which had the start detent in it. Works great. I would assume someone changed out the original switch. The push button looks factory with rubber cap over it. Why did they have a separate push button for the starter? Did I screw up by not using the push button?
