wd oil pressure
race tractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote race tractor Quote  Post ReplyReply Direct Link To This Post Topic: wd oil pressure
    Posted: 16 Dec 2016 at 11:43pm
I have a 1950 wd and the oil pressure gauge is always all the way up at idle or wide open until worm I used the tractor all the time for the last 3 years and ive blown 2 oil filters in 2 years ive used 5w30 oil 15w30 oil 5w20 it all makes high pressure any ideas are welcome
ps I don't need to fix it
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2016 at 11:56pm
I never use 5w anything in a WD. Always used 10w30 with no issues for 25 years. Oil pressure gauge always end up between "ORM" in normal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote race tractor Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2016 at 12:06am
I use 5w any thing more makes the oil filter blowup
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2016 at 12:59am
if it's blowing the filter' the little piston for oil is stuck' it's behind that large bolt on the side of the block' needs to be freed up.
