175 hydraulic pump coupler shaft
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: 175 hydraulic pump coupler shaft
    Posted: 01 Jun 2010 at 9:47pm
Well today  I was mowing with the 175D and I lost my steering and then realized the mower was in the dirt.  Stopped to take a look and the shaft to the front pump was not turning....so I loaded it up on the trailer, hauled it home and finished up with the 170D. Tonight I took a look at the one off of my parts 170 and see someone had welded the coupler solid to the shaft. Obviously a weak point of the hydraulic system. I'm wondering if I should just weld this one together.....or will it put stress on the crank or front bearing and seal? The front seal was a leaker on my parts 170, wonder if the welded up shaft might have been a cause? Also does anyone know where you can find a shaft for these, I am assuming the splines on the shaft are gone....
ALLIS EXPRESS!
This year:
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 10:29pm
That happened to our 1977 175 some years ago.  I think we got a machinist to fabricate a new one for us.  Can't remember that long ago!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 11:17pm
I'm thinking of taking the welded one and cutting it in half and adding a Lovejoy coupling with the rubber spider .....wonder if it would last? Problem is it is probably a 4 hour job to change them out...think the sheet metal and radiator have to come off....
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 6:12am
I would think a lovejoy coupling would work Eldon. It might be better to spend 4 hours on that than to shake the front seal out with the welded one.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 6:16am
are the shafts the same for gas and diesel?
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 6:30am
There is a AC Bulletin regarding the close tolerance on the pump alignment, be sure you don't get things running out of alignment or you may be kissing the pump goodbye.
niel ev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 8:55am
Eldon we got a shaft for a 175 a couple of years ago from a Ford dealer hope thie helps Niel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 1:20pm
Wow it only took me an hour to get it apart...just took the air cleaner out and removed the sheetmetal cover above the chain coupling and got that off, then removed the cover above the axle and got to the bolts on the flange.  Bad news is the flange and shaft are both worn out....guess I will go see what I can find in town....
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 1:30pm
WOW! I just got off the phone with the local dealer...he has the parts...for over $800! Think I will check my options elsewhere....
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 2:54pm
First place I stopped had a splined collar for $11....I bought it. My buddy is machining a pilot id in it and then welding it to the old flange. Fortunately there was an inch of extra spline machined into the shaft....should be good for another 35 years.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 2:58pm
So  Eldon, exactly what parts would the $800 have bought from the AGCO dealer vs what you did?  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 3:03pm
The flange that bolts to the crank pulley was around $650 and just the shaft that goes in it was around $150....I just remember adding them up to $800 in my head and thinking there has to be a cheaper fix! Parts guy was even stunned....
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 4:09pm
Eldon just talked to ac your dealer is double what I have to pay for coupler and not to bad on the shaft Niel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 2:42pm
Final look after welding on the $11 coupler. Can't even tell it wasn't made that way.
ALLIS EXPRESS!
This year:
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 4:17pm
You could have that whole outfit made from scratch for $100.
 How will we ever survive without AGCO parts support for Allis Chalmers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 6:27pm
Well there are some fancy rubber dampners and sleeves in the flange....probably what drives the price up.  I got it together and I still have 1/2 of spline left for next time....
ALLIS EXPRESS!
This year:
