Water pump
Bob C IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Topic: Water pump
    Posted: 16 Dec 2016 at 1:58pm
60 psi boosts!!!! What should min pressure pump should be used??
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2016 at 3:14pm
Didn't know there was a relationship between the amount of boost pressure and the water pump? Less you are referring to something else?
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2016 at 3:47pm
Water injection pump. It injects water in the intake to cool the air.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2016 at 4:12pm
Completely misunderstood that one!    Here is one I used in the passed works very well
http://www.coolingmist.com/pagedisplay.aspx?feature_key=water_pumps
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2016 at 4:33pm
It would also depend on if your injectong water before or after turbo. Some use Windshield washer fluid tanks with pumps in the tank already to inject before turbo. If it's after turbo I would say 150psi or more so you can do 1 or more nozzles. I would recommend a shut off Solenoid too so it won't self siphon. All that you can get from the link
"coolingmist.com"
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2016 at 2:36pm
If its after the turbo, the more pressure the better. Higher pressure equals smaller droplets. Smaller droplets are easier for the engine to consume. I think the Simpson and many other good water injection systems run from 1000 - 1500 or more psi. Be sure to use nozzles that will handle whatever pressure the pump will provide.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2016 at 6:35pm
Sorry folks fighting ice here in Illinois.. yes water injection. Think I'll just go in front of turbo for a cheap easy fix..
This page was generated in 0.058 seconds.
