Magneto Timing for a B?
00transamnh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00transamnh Quote  Post ReplyReply Direct Link To This Post Topic: Magneto Timing for a B?
    Posted: 16 Dec 2016 at 11:07am
I found a great how to for Mag Timing on a B, however the images are no longer active on the webpage (See below)
http://personalpages.tds.net/~thompson_wp/acb/magtiming/magtiming.htm
Does anyone have a link to timing these FMJ set-ups correctly with pictures?
...or if DAN(NH) is active on this forum... are the images still around?
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2016 at 1:30pm
I think this is what you're looking for:
http://rodnh.byethost12.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2016 at 4:48pm
One problem for somebody just learning might be this.
"The FIRE mark is visible in the opening when the number one piston is 30 degrees before top dead center on the compression stroke. The CENTER mark is visible when that same piston is at top dead center (TDC), also on the compression stroke."
These marks ARE visible on the exhaust stoke as well. That is why it is imperative to determine which stroke the number 1 piston is on at the time.
Edited by CTuckerNWIL - 16 Dec 2016 at 4:49pm
