2 point for a B
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: 2 point for a B
    Posted: 01 Jun 2010 at 5:53pm
I wanted to try out a PTO finish mower I have with the B, has anyone made a 2 point attachment system? I don't need to lift the mower, just drag it along behind the tractor.
I need to get a overrun clutch, the B is 1 1/8", what is the standard PTO shaft size now?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 8:47pm
i have a very heavy old 6 ft disc that i use with the B. Its too heavy to lift. I use the bottom two arms of the 3 point hitch to raise and lower the disc. I have a 8 inch trail wheel out a foot behind the disc that lets the disc pivot up and down on it. You might be able to do something like that. I have a drawbar on the front of the disc that pivots in the center when connected to the 3 point arms. That lets me turn slightly with the disc in the ground........... New PTO is 1-3/8 diameter, 6 spline. You can buy adaptors for the 1-1/8.
countryguy828 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote countryguy828 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 8:52pm
Here is a pic of me loading my B onto the trailer with a woods 6 ft 3 pt mower.
It does make the front end pretty light. I am hoping the new front weights Fred Winner made up for me take care of that problem.
It does fine pulling the mower. Biggest issue I have had was trying to mow wet grass that was taller than the front tires. It didn't care for that much at a time, taking less of a swath for the thick stuff was fine.
Currently this tractor is dis-assmebled for paint.
