Carb question
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Topic: Carb question
    Posted: 01 Jun 2010 at 5:14pm
can you force air through a updraft carb. i want the put a electric supercharger on my WD, but im not sure if air can be forced through a carb.
Thanks, Carl
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 6:16pm
I don't see why not.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 6:23pm
 I'm sure you would have to tighten it ut up as they are meant for suction and not pressure, how much boost are you looking for?
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 7:33pm
Any blower setup that blows through the carb will have to be able to pressurize the float chamber to the same pressure as is forced through the carb otherwise fuel will not be pulled through, in fact it would probably be forced out of the float chamber.  Stutz and Mercedes  used this system in the late 1920's. Also, fuel would have to be delivered to the carb under pressure from a pump. Gravity flow as used on the WD wouldn't cut it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 10:06pm
not looking for a lot of boost. i dont move that much air, just want enuff to get me to the top of the class
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 10:20pm
leafblower works better.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 10:33pm
If I'm not mistaken, you need to build a box around the whole carb and pressurize it, so that vents and metering ports are equalized.
