WC shifter
JohnDNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnDNY Quote  Post ReplyReply Direct Link To This Post Topic: WC shifter
    Posted: 01 Jun 2010 at 4:32pm
I have a WC that when I shift it in third gear it falls out. Doesn't pop out when running just when you first put it in. Any ideas. Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 4:43pm
Above the shift rail there is a spring and a ball that is supposed to drop in a notch to act as a detent. Your spring may be broken or the rail may be worn down. I think you have to slide the shift rail forward to clear the ball and spring. You will probably need a repair manual to get this apart and back together. Buy one from this site and help support it.  http://www.3000toys.com/allis/products.asp?cat=2&type=books&find=ACWCWFRC
This page was generated in 0.709 seconds.
