WD oil pressure and oil leak questions
Pete32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete32 Quote  Post ReplyReply Direct Link To This Post Topic: WD oil pressure and oil leak questions
    Posted: 10 Dec 2016 at 8:15pm
Hi everyone, I'm new to the site and tractors.  Thank you for all the great information and knowledge you share.  I have 2 questions about my 51 WD that I just bought.  When I got it the oil pressure gauge wasn't moving.  It is an allis chalmers "NORMAL" pressure gauge.  I unscrewed the gauge and hit the back side with a little compressed air.  The needle freed up.  When I put it back on the mount and started the tractor, the needle moved between the "OR" in Normal.  When I shut the tractor off, the needle moved back down. Should I still replace the gauge or do you think it's good to go?
Also, the oil pan was leaking in the front and back (curved sides).  I haven't noticed it leaking anymore.  Is it possible for the oil leak to stop on it's own?  Thanks again
Edited by Pete32 - 10 Dec 2016 at 8:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2016 at 8:57pm
I'd keep using it, ORM is about normal, for that vintage of motor. You have to remember the rule of thumb of 10 lbs/1000revs, most that motor puts out would be about 25 PSI.
both probs could just be from a long nap...
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2016 at 9:00pm
sounds like your gauge is working. OR is the normal pressure range and it can run to the N and still be ok. The oil leaks probably will NOT seal themselves. Watch the video on this site about putting a gasket on. A lot of gaskets are put on wrong and leak Bob
Edited by Chalmersbob - 10 Dec 2016 at 9:00pm
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete32 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2016 at 9:05pm
thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2016 at 9:13pm
I believe 7-12 LBs are about max.       MACK
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2016 at 7:11am
Any pressure at all is good. Just beware of low oil pressure being caused by the wrong oil filter.
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2016 at 7:19am
First WD I had was about 3 lbs. The one I have now is about 6-7 lbs.
Father in laws 45 runs 17 on a new overhaul.
If they don't leak somewhere something is wrong.
Unless it is pouring out I would just use it.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2016 at 10:33am
It is allowed to leak for it's age and there is no guarantee that after you replace the gasket that it will not still leak. Any reading you get on the oil pressure gauge means all is well so unless it keeps sticking I would not replace it.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2016 at 5:00pm
We need pictures! Welcome to the forum! Your doing good! Oil pressure sounds OK. And yes they leak. Sounds like you need to pull the pan and do the gasket thing. Check Dons  MO's video on oil pan gasket. I did both mine with out pulling the engines, But as Don will tell you the best way is to pull the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2016 at 5:26pm
Yeah, when you get old, you'll have some leaks too......take it from someone who knows! Big smile
Here is the thread of the oil pan replacement.....how bad is it leaking??
Hot Sticky Topic
Oil pan Gasket video
As long as the needle is moving on the oil pressure gauge, it should be good.  When you shut it off, does it drop down to the left?
There's a LOT of stuff to help you in the following;
Farm Equipment -Knowledge Base
and the
Forum Talk
If you need anything, just take a look.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete32 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2016 at 12:44pm
Great video, thanks everyone
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 11:05am
Be sure it is the oil pan gasket before you go all out on replacing it. If the rear main seal leaks, it looks just like the pan gasket is leaking. If you pull the engine, might consider replacing the crank seals at the same time.
www.awtractor.com
A&W TRACTOR 920-598-1287
