A 190XT is basically a 200?
Daniel Christensen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Topic: A 190XT is basically a 200?
    Posted: 01 Jun 2010 at 11:23am
The way I understand it the 190XT kind of "became" the 200. So the 200 is just the name for the newer 190XT's, they are the same tractor?
CAx3, Bx2, G, D17x2, D14x2, D15, D19, 190XT, WC, WD-45, 185, Gleaner K.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 12:13pm
The 190 XT series 3 "evolved" into the 200. Larger eng oil pan and pump and dual oil filters (front axle dropped a couple inches for the change)...different turbo-charger....lower compression pistons (15 to 1).....larger ring and pinion gearset in the rearend.....slower 1-2 gear in the trans.....wider bull gears and bull pinion gears.....torsion bar on the 3-pt has fine spline ends instead of "hex" shaft..... A 200 is 90% a very late XT.
