d12 hard steering
c linn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote c linn Quote  Post ReplyReply Direct Link To This Post Topic: d12 hard steering
    Posted: 01 Jun 2010 at 7:06am
 I am looking for a power steering unit for a d12 series 3 tractor is getting hard to steer
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 7:47am
My D12s both had hard steering. Turned out that the gear box on the torque tube was in dire need of rehab. Removed, diassembled, cleaned out 50 yrs of gunk, rebuilt the upper and lower bearings (balls fell out & races were somewhat pitted...esp the top bearing...from yrs of inadequate lubrication). Was lucky in that the worm and pinion pin were not damaged. Reassembled placed the bottom bearing/race on the top and the top bearing/race on the bottom (bottom bearing/race is always in lube), new seals and fresh 80 wt gear lube. Steering is much improved.
Post Options Post Options   Thanks (0) Thanks(0)   Quote c linn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 5:19am
Steering box is worn and needs a worm and pin Have not been able to find parts
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 6:40am
What does the D12 use for a steering box? If the same as the CA, there's a source for some of the parts.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote c linn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 5:45pm
This is series 3 it uses a different box
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 7:56pm
  check frt. spindles  [grease]
