Gleaner L dimensions
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner L dimensions
    Posted: 05 Dec 2016 at 5:49pm
Could somebody give me these dimensions for a Gleaner L, I need the inside width between the front and rear tires. 14L-16.1 rears and 23.1-34 fronts. Also is the cross steering rod below the axle and how far. TIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 10:51pm
The rod is below but have no idea how much
critter View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2016 at 12:27pm
Inside the front tires is 82 inches
Inside the rear tires is 92 inches
The tie rod hangs down about 4 inches below the axle, but not below the spindles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2016 at 1:02pm
Thanks that's exactly what I needed to know.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2016 at 4:46pm
Width between tires depends on which way the tires are turned. With the tires out wide you run between the rows. 4 30 inch rows.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 10:37am
with some narrow dish rims off a L in 18.4x34, one will barely fit on a 102" dropdeck.
We hauled one this way, and the 14Lx16.1 4 ribs were hanging onto the deck by 1 rib, so it was a tight squeeze. :)
We took plenty of blocks and let air out of tires to put weight on the frame and off the tires.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
