Unstyled WF Fenders |
Post Reply ![]() |
ZachD89 ![]() Orange Level ![]() ![]() Joined: 24 Dec 2015 Location: Littlestown,PA Points: 690 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Nov 2016 at 4:42pm |
Would anyone have a good set of fenders for a unstyled WF for sale? Thanks Zach
37 A,37 Waukesha B,35 WC,38 WF,M crawler,49 WF,49 WD,53 WD45,39 and 40 RC,47 WC,41 B,39 B,48G,48,C,59D10,D21,IB,B10,B12,B208,B1,Roto Bale Loader, sp100 combine, allcrop 66, L3 Gleaner
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11643 |
Are the unstyled WC fenders the same? I have a brand new set... I know the styled fenders for the WC are different from the styled WF. Clamshell design is the same, but the mounting brackets are in different positions...
Thay are not the same. The unstyled WF fenders are different than the unstyled WC fenders
Edited by ZachD89 - 30 Nov 2016 at 5:05pm |
dawntreader74 ![]() Orange Level ![]() ![]() Joined: 28 Oct 2013 Location: Manteno Points: 1763 |
are they shorter then the wc fender' like a wc fender cut off at the back an the front' if so i have a set. very good ones..
B26240 ![]() Orange Level ![]() Joined: 21 Nov 2009 Location: mn Points: 3860 |
The unstyled WF fenders are indeed shorter than the WC's When I did mine I used the inner panel from the old WF fenders and then put cut down (shorter) WC fender on them. I used pan head stove bolts to fasten them to the brackets and filled the screw driver slot with bondo to look like the rivets originally used.
sounds like the ones i have' the top are same as wc' an short' sure like to see one..
Darrell G (MN) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Green Isle MN Points: 1496 |
Zach, we make new ones for a WF along with many other unstyled fenders, if interested please call and we can discuss building a set for you. 612-280-3397
There ya go Zach! You won't be disappointed I can tell ya that! The fenders I have for sale are made by the Grams Bros. Workmanship is impeccable! They make some beeeutiful stuff! Now if ya we're talkin' about the ole' man, well, that's another subject...! LMAO!!
Your so kind little fella, I was going to be nice to you steve, but you make it difficult. Zach these fenders will be impressive on that WF, there is a set om my unstyled WF and they look good.
Post Reply ![]() |
