Firestone 26 x 12 x12 |
KevinON
Joined: 07 Dec 2009 Location: Schomberg, ON Points: 810 |
Topic: Firestone 26 x 12 x12Posted: 30 Nov 2016 at 3:48pm |
I have a chance to buy a new set of Firestone 26x12x12 23 degree tires for a stock altered 716 6 speed that I am building. I was going to get a set of puller tires for it, but do you think if these were sharpened, that they'd work? We have predominately loose tracks. I was concerned that they'd dig a bit too much. Thanks
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55212 |
Posted: 30 Nov 2016 at 5:53pm |
23ยบ firestones are one of the best tires out there. Try them first, before grinding anything away, is my advice... Also try them at various pressures, to match track conditions...
HD6GTOM
Posted: 06 Dec 2016 at 12:14pm |
We put a lot of those on for the guys and gals pulling in past years. I don't remember any of them being cut, sharpened, or ground down.
ac720nut
Joined: 09 Feb 2016 Location: Dexter Mi Points: 1217 |
Posted: 06 Dec 2016 at 1:00pm |
Used them for years back then there weren't all these different tires to chose . I'ld chose a set of stones over anything out there, any Idea how old they are? The older harder a tire is
KevinON
Posted: 07 Dec 2016 at 7:10am |
They are brand new, apparently. Guy doesn't want them. He is going to use puller tires.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4063 |
Posted: 07 Dec 2016 at 10:36am |
ive got them on a cub kadet with 12.1/2 inch wide wheels running onley enought air to keep the valve stems in the holes mine are new and soft and un cut when i pulled last it didnt hook like the cut one s just spined out so i think i will have to cut mine . i am watching for a b112 to tranplant all my puller parts to
KevinON
Posted: 07 Dec 2016 at 10:58am |
I have a 716 and a B110 that I will be pulling with too.
ac720nut
Posted: 08 Dec 2016 at 5:42am |
HudCo, you might check with CasinoJim on simple tractors, he 's out your way and seems to be able to find a lot of those tractors. just a thought if your looking.
