HD6 Dozer drivehaft to transmission Came apart |
Darrell90
Joined: 23 Jun 2016 Location: West Virginia Points: 9 |
Topic: HD6 Dozer drivehaft to transmission Came apartPosted: 30 Nov 2016 at 1:25pm |
While I was pulling a tree there was a pop, when I inspected it I found where the drive shaft goes into the transmission wasn't centered or sitting right anymore I removed the drive shaft I don't know what else to do. It still runs and it will roll downhill in neutral. pics WONT UPLOAD TRY AGAIN LATER HELP!
gemdozer
Posted: 30 Nov 2016 at 3:24pm |
The rear drive shaft is bolted to the imput shaft and the input shaft in lock in housing by the bearings snap rings
Darrell90
Posted: 30 Nov 2016 at 5:58pm |
so you think the snap ring probly broke,if so I need to remove the front housing that also has the shifter on top and replace snap ring . when taking housing off do you have any advice, Im a little worried how the gear shifter adapts to the main trans. Thank you tons,This dozer is as old as me.
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 30 Nov 2016 at 10:51pm |
they made them things that long ago? (poke,poke)
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1009 |
Posted: 01 Dec 2016 at 3:11am |
Just be thankfull.
I found that I needed (badly) a cross kit for the back U-joint on that shaft for a FA 10. Supplier's comment was "Just as well you found that. If that lets go it usually takes out the front cover of the transmission" |
Dozer
Joined: 16 Aug 2011 Location: SW New York Points: 689 |
Posted: 01 Dec 2016 at 6:47am |
Are there generic yokes and cross parts for the drive shaft? The salvage parts I find are usually as beat up as the parts I am trying to replace.
gemdozer
Posted: 01 Dec 2016 at 6:53am |
The input shaft rear has a bearing and the end pinion shaft go in the input shaft rear bearing
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 01 Dec 2016 at 8:01am |
if it is the input bearing you should be able to repair without going into the transmission. it is located behind the 4 bolt retainer that holds the seal. the bearing should have a snap ring on it that locates the depth of the bearing into the case. its possible the snap ring broke and allowed the bearing to move inward into the trans or the bearing is out. when you remove the input yoke and bearing retainer you will see what is going on.
Dad- WD, D17D, D19D, RT100A, 7020, 7080,7580, 2-8550's, 2-S77, HD15 |
gemdozer
Posted: 01 Dec 2016 at 3:29pm |
I should have these parts ,yoke,input shaft and bearings
Darrell90
Posted: 02 Dec 2016 at 10:13am |
when I take the housing that bolts onto the front of the trans,that housing also has the gear shift on top and the input shaft in front, how will the gear shift attach to the trans. thanks
CAL(KS)
Posted: 02 Dec 2016 at 11:15am |
ok i looked at the parts book. its a little different setup from the bigger dozers but still not too problematic. looks to me like you will need to remove the shifter and then the front housing can be removed. the input shaft will come out with the housing and is supported on 2 bearings in that housing. the shift rails should stay in the transmission and not give trouble once the shifter is removed. the shifter is on a swivel which is bolted from either side at the top of the shift tower. pg 126 of pdf.
hopefully someone with experience or a service manual can confirm this you can see the parts breakdown here. pg 122 of pdf
Edited by CAL(KS) - 02 Dec 2016 at 11:16am |
gemdozer
Posted: 02 Dec 2016 at 1:25pm |
You need to removed each side shiffter lever and pull the lever from the notches and you have the boot seal ass and 2 seal rings on input shaft
Darrell90
Posted: 02 Dec 2016 at 1:30pm |
Thank you I really aperacate the help
