M4 prime mover
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: M4 prime mover
    Posted: 29 Nov 2016 at 6:03pm
Auction time has an allis chalmers M4 prime mover coming up for auction. I never knew that Allis made such an animal. It has a 4 cylinder, 2 stroke detroit in it, it rides on rubber tracks, has a fifth wheel plate, air for semi trailers, two pintle hitches, and a big ole winch on it. I wonder what it has for a transmission? Anyone know? Check it out; it's pretty cool. Also referred to as a sand hog. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 6:55pm
Long ago jus Outside of Rolla MO an old fella had a scrap yard and had to have had a dozen of these sitting along I-44. Back in the 70's he passed away and they all disappeared.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 8:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 5:13am
 [TUBE]http://youtu.be/BTbG8JanBog[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 8:45am
I now have another allis item on my Christmas list. Darrel
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 9:03am
there was one at Hutch Darrell
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 9:06am
if'n you buy one of them, i'll hafta add another water line to the machine!
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 9:28am
I thought they had a gas motor in them?
Heavy at 30,000+ lbs.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 9:28am
What's another water line going to do. I think you already got the aquafer sucked dry. I suspect that the next step may be to run a line from the Missouri River. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 9:31am
I am a little confused, too, Charlie. Son was doing some looking at them on the Internet, and it said that they have a Waukesha gas engine in them. I suspect that they made them either way. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 9:38am
Data Sheet
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 9:40am
3 Speed with a high and low range
The diesel may have been added later in life
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 6:40pm
me thinks Cody gots to ride in the one at Hutch
caledonian View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote caledonian Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 5:53pm
Allis Chalmers manufactured a M6 prime mover as well. It weighted 76000 LBS and was powered by 2 Waukesha 6 cylinder gasoline engines 190 HP each. Top speed 21 mph. Designed to tow heavy artillery such as 8 inch or 240mm M1 howitzer's. How would you like to have them rumble through your neighborhood ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 6:17pm
Not MY neighborhood, but Brawltimore could use a few of 'em...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 9:07pm
Wow! Allis did make some pretty awesome stuff. Darrel
donoman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donoman Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 11:13pm
The M4 and M6 look as modern as tomorrow, great design from 70 plus years ago
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2016 at 2:24am
sooooo....who owns the one that was at Hutch?
Josh H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh H Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2016 at 10:11am
Yeah i have my eye on it but i already bought
A 16b and a 300 horse tub grinder this year.
Rebuilding tub grinder currently and Ok. Is
A ways from Ga. For trucking so i'll have to
Stand down on this one but it would pull my
Grinder nicely on off road jobs.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2016 at 8:21am
Thanks for posting I saw 1 in a military museum once.
Farmerhg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farmerhg Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2016 at 1:14am
Does anyone know why the one on AuctionTime looks so much differant.It doesn't really look like the same machine.I think even the motor is in a complete differant location.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2016 at 4:20am
Someone took the M4 chassis and redid the top configuration to suit what they needed
Charlie
Bob (IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob (IN) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2016 at 9:08am
I need help finding this on auction time
great-grandpa's wc with picker, 20/35, speed patrol, uc, m crawler, 620, 653 dozer d21 d17 d19
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2016 at 1:13pm
once you get onto auction times website, the first thing coming up should be construction equipment, followed by the most popular brands listed, then below the brand names is "more". Click on that, and many more brand names will pop up; one being allis chalmers. Click on allis chalmers, and it should be right there. Darrel
Lee (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lee (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2016 at 1:25pm
As said, gas engine from the factory.... post war these were sold a surplus to mining/logging/construction , were repowered with everything under the sun, chopped up and welded on and are now far from what they were. An awesome machine!, there are several restored ones in the central US, and are very expensive to restore to factory condition.
Lee
B212
912
Willy's Jeeps
Gleaner K
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2016 at 8:41pm
If you search on youtube the one in Nebraska came from the Chambers NE phone company. they used it back in the day to install telephone lines. They repowered it with a cummins and it got sold to a local kid there who posted videos on youtube of him driving it.
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 8:18am
Here ya go Shameless. It was an impressive machine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 11:12am
Be danged, Cody did get a ride in it. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 10:30pm
Thanks Tim! that is a cool machine!
This page was generated in 0.323 seconds.
