no power steering 8050
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Topic: no power steering 8050
    Posted: 31 May 2010 at 1:22pm
Hi All
On Sunday morning the power steering on the 8050 quit what could cause this
Morley
Farm stuff 8050,6690,175,F2,5050,WD
everett048 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 2:54pm
No fluid?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 3:00pm
fluids are good
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 6:54pm
Lack of info here. 1. Does the tractor even move??........in ALL gears?  2. Will the remote hydraulics raise an implement???  3. Does the steering wheel move very freely?? (like splines worn out on the steering shaft)???  4. Are there any unusual noises when the engine is running???
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 8:16pm
We used the tractor Saturday afternoon everything works but the power steering no unusual noises The steering wheel turn freely for  1/8 of a turn then it feels like it is going grab the tie rods attempt to move as you continue turning the wheel it comes to a free zone again
thanks
Morley
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 8:32pm
  Splines on the steering wheel shaft that mate with the orbitrol have failed I'll bet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 8:36pm
Perhaps thought there is no mechanical noise or feeling. Its off to the repair shop I will keep you posted
Thanks
Morley
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 7:31pm
Dr.Allis
You were close the problem was the universal joint in the steering column broke. Agro doesn't stock this part anymore. So the shop repaired the part
Morley
