Allis chalmers diesels vs the rest..
nick121 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers diesels vs the rest..
    Posted: 23 Nov 2016 at 5:18pm
hey, Just curious how you guys rank allis chalmers diesel with the rest from that time?
Like the 426 and 301
I read how the 426 isn't great when pushed to the higher end. But probably at suited in the 7040-7060 tractors
The 301 seems like a great engine
The 354 perkins seem good in the Masseys and other tractors
I love the old diesels and they all sound different lol. My massey 165 had its own sound, And the 990 david brown had a cool sound too. I love the sound 426 in my 7040.
I always like reading stories from back in the day what farmers were pulling and stories of tractors that were turned up.  Just looking for a good conversation about the diesels in tractors.. Also how would you rank the older engines vs the ones of today?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 6:53pm
Well VS a tier 4 diesel, of today, they are all angels, to fix...
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 6:56pm
They are good engines, and people have really wrung some impressive horsepower out of them.
IMO they were pushed to their limits in a few applications where an engine change would have been the best route, like the 7080 tractor.
In a 7040, I am very happy with them. in a 7060, I prefer the 478 Hercules that is found in the 2-155 White tractors.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
bakwoodsfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 6:57pm
AMEN TO THAT ONE
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 8:06pm
I had a lot of hours on a 7045 back in the early 80's and lately have quite a few hours running an 8110 green and Yellow thing. The newer tractor doesn't have anywhere near the low end torque the 426 had. The Allis was original at the time with quite a few hours on it and the newer green one has had to have all new pistons and sleeves in it with very few hours of work. You could also by 2 running 7045's for what it cost to fix the engine in the JD!
 I never cared much for the PD tranny when I had to come out of a field and head down the road with 500 bushel of corn behind me and the JD has a button to push to go up or down in gears, but that old 426 had REAL guts to it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 8:15pm
Why didn't you care for the PD in it ? That transmission and Power director  leaves options a little faster by shifting , or down shift to go a little slower ; what more could you ask for ?
Edited by DougG - 23 Nov 2016 at 8:21pm
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 9:00pm
A powershift! Got 2 ps and 1 PD The power director is a pain
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 9:05pm
Not geeked about the 301 cold blooded, fuel hogging, under performer. The 200 cui used in the 6080's might be the best non Cummins I have seen. Nothing wrong with the 426 as set up for a 7060. The little Perkins my 160 has will start as cold as 8 F without help.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 9:18pm
If only the 7080 could have had a PS and the 670HI turned a few hundred RPM less. And if the 7000's all could have had the throttle in the console like the 200 did. 35 years and I still complain as if AC could still change their ways for me. I guess they won't.
I look around and I don't see many 30-40 year old tractors still out on the job like our old AC's. I'm sure they are out there, but tractors in the 100-200 HP range are hard to find.
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 10:46pm
For that era, it would be hard to beat the IH DT466. Take a DT466, coupled to a JD 40 series Quad Range, with a White rear end, and an AC 8000 cab. That would have been a tractor. Personally, I think AC, should have stopped at the 7045 with the 426, and found something larger for the tractors bigger than that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 7:32am
I said, the problem I had with it was when pulling 4-500 bushel of corn out of the field and have to head down the road. There is no way to get from 6 mph to road gear without stopping to shift. Then you have to take off from a dead stop in the low side and slip the clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 7:52am
I can see the day coming when farmers pull out their old tractors and have them rebuilt. In this day of Obama enviromental madness, the new tractors are just a pain to deal with. The tier engines are constantly giving issues after a few hours are put on them. Transmissions are run by computers, push button junk. I watched a mechanic run up and down the equipment yard with a laptop attached trying to resolve a shifting problem on a new Case/IH for over an hour. Valve body pressure problem. I wasn't looking for a tractor just there doing some phone repair. I won't buy nothing but AC. Darn, I'm wrong, I bought a Mahindra 26 hp compact last year, loader , belly mower, backhoe, yard rack package. Awesome little fellow.
I will keep our Ac's running and love the PD that moves them all. Well, the 6060 doesn't have one but the turbo power over comes that. Still wish it had one. Wish the D21, 210,220 had them too. No I don't have the big boys, but always thought they should have had them. My 190 xtd id the biggest I have and what a great tractor it is. 301 has the power and the PD is priceless.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 8:36am
I know I'll catch flak for this but here goes. The power shift is out on the 7060 so I hooked the 7045 pd to that big Brent. I started in 4 and used the foot throttle to get some speed up then dropped throttle, clutched and pulled into 5 and didn't grind a gear. Dead start in 5 seems awful hard on clutch
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 8:41am
Yeah mostly  you can shift those like a truck , just let off and slide it in gear
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 12:51pm
Yeah, In the 7040  usually start in 3 or 4 pulling wagons  And shift it like a semi, dont even use the clutch sometimes.. no grinding if you do it right.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 4:00pm
I love shifting my D-21 and 220 like a truck. I guess we'll call the transmission an 8 speed Field Ranger. I don't have a foot throttle so it's not quite as easy but almost 50 years experience helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 5:10pm
Haha. I like that one (8 speed field ranger)
I can downshift okay too most of the time while hauling wagons.
If im not pulling a wagon I will usually just start in 5 and low on power director then go into high power director.  Sometimes I will start in 4 though even without a load.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 5:38pm
I will take a power director tractor over a powershift...no comparison in my opinion.  I can shift my 305 with a loaded cart of 900 bushel up and down whenever I want to, no issue what so ever.
The problem today is the electric shifting power shift transmissions are making the day of driving the tractor using all your senses is gone.  The nice thing about those transmissions is you only have to fix a mechanical problem, you don't have to diagnose and electrical problem then find out that the electrical problem caused a mechanical problem you now have to fix.
I work on newer engines/trucks every day...just have no idea how owners can afford the new tier complient engines, they are way over priced parts and they are always eating parts up, not our old 301s and 426s...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 6:47pm
I shift the 7080 in high range from 2nd to 3rd, then step on the high floor button. If you miss, DO NOT try again. Stop, then try again. It is a great feeling when you have done it right and your in 5th high on the floor.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 7:30pm
From the 80s at the risk of bringing up a bad name I like the deutz air cooled motors with a intake air pre heater. We had one in a Same tractor.   Hated the tractor but loved the motor it burned muck less fuel then our older case or the IH 986 we had doing the same job just running a genorator.
With the pre heater on the incoming air that motor would start down to about 15 below like it was a summer day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 8:18pm
Their was a Duetz dealer 3/4 mile from where I live. So the neighborhood HAD many all but a couple are gone. One guy scrapped in favor of a older Deere. The two I have been around were broke more than they ran. I remember sticking a salamander heater in the R52 engine compartment to get it going when it was barely below freezing
Edited by victoryallis - 24 Nov 2016 at 8:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 8:37pm
I hated the tractor but we ran it on the Maurer spreader all winter because it started easier then any other tractor we had. Just let the pre heater run for a few minutes and it would fire as soon as it cranked over. The Same pre heater had a fuel line running through it if i rember correctly so the motor got a blast of warm air and fuel. It fired right up them rattled like it wanted to explode for about 5 minutes and was off and running.
And it ran on about 25% less diesel then our IH when it was on the genorator.   The rest of the same tractor belonged in the scrap yard total garbage.
Edited by Dan73 - 24 Nov 2016 at 8:42pm
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2016 at 9:32am
I've never witnessed s fuel hogging 301. If you liked the 200 then you should like the 301. It's the same engine with 2 cylinders cut off.
Wink
I am a Russian Bot
Mike Plotner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Plotner Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2016 at 9:00pm
fuel hogging 301? with one in my 190 XT set at about 115 horse, I worked 22 acres with a 18 foot field cultivator, planted 22 acres of corn with a 12 row deere 7000 planter then planted another 80 acres of beans with the same 12 row planter before having to refuel. cold blooded, yes, but under preforming and fuel hogging? no way!
2001 Gleaner R42, 1978 7060, 1977 7000, 1966 190 XT, 1966 D-17 Series IV and 1952 WD and more keep my farm running!
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2016 at 10:37am
When the 7000 was the tillage tractor I fueled it at the start of the day, lunch, and at supper time. When we had a PTO batch dryer the the 6080 could go 20-22 hours on a tank. When we went to 11 shank 1000 gallon side dress applicator we started out using the 7000 this past year I put the 6080 on it.   Same job the 6080 used noticeably less fuel.
Lots of 6080's running over 100hp.
Edited by victoryallis - 26 Nov 2016 at 10:40am
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2016 at 8:28pm
6080 is a light weight vs a 7000 by several thousand pounds that's why it uses less fuel and seems snappier. A 7010 feels like a slug compared to a 7000 using the same engine because of the weight difference. Load a 6080 to the weight of a 7010 and you'll have a real pooch.
Wink
I am a Russian Bot
ironac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2016 at 9:06pm
301 a fuel hog? That's crazy talk. They are pretty powerful for the size they are and they sip fuel.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2016 at 9:55pm
You might think they sip fuel, only if you've never run a Ford or anything Perkins powered.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Plotner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2016 at 10:04pm
true, I've spent a decent amount of time on a neighbors 285 and 596 Massey's with perkins diesels in them. both are way better on fuel than a 6200 or 2640 deere. haven't had a chance to run one that would be comparable to a 190XT size
Post Options Post Options   Thanks (1) Thanks(1)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2016 at 7:23am
According to Nebraska tests the 190xt with the 301 beats out the comparable Ford 8000 and Massey 1100 in fuel economy.
