WD engine codes
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: WD engine codes
    Posted: 30 May 2010 at 8:17pm
will a sleeve/piston interchange between a GA and a PA?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 8:48pm
Lou, It should fit but just changing one? The compression ratio might be different. Of course what is in the engine today might not be what was put in it when they stamped the engine number on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 8:58pm
Ya' Charlie, it was the compression ratio I am concerned about. I can't find any info on a PA, don't know what that is. I have two froze up motors and I figured I could make one out of the two on the cheap.......maybe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 9:03pm
There is really no way of knowing what is in either engine without opening them up and pulling the pistons.
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 7:24am
Lou, I may have a WD engine for sale. Maybe I will part it and send ya the pistons and sleeves? Haven't decided what to do with these tractors I bought yet.
