serial number for a model E
psheridan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote psheridan Quote  Post ReplyReply Direct Link To This Post Topic: serial number for a model E
    Posted: 20 Nov 2016 at 9:28pm
Where do I find the serial number for a Model E
I have a number of 40523 on the left side of the block
this didn't seem to jive with the serial number chart on the site
thanks
Paul
Norm Meinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2016 at 9:47pm
The serial no. is in front of the gear shift lever on top of the axel housing.
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2016 at 10:08pm
I love to see posts about the 20-35's, when you figure out what you have be sure to share the rest of the story with the whole class!Wink
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 9:43am
Some of those serial numbers were stamped pretty faint.  Depending how much rust is on there, it might be pretty hard to see.  Take a good wire brush to it and a strong light off to one side.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 12:08pm
Frist year short fender was on dash - firewall . When calling it a E is it a 20-35 or 25-40 .Where is water pump side of engine ,or mounted on front of engine.
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote psheridan Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 6:59pm
Thanks for the info
I will check on the gear shift housing
thanks a ton
I will get back with you all
Paul
